So, I don't usually post here because I like to figure stuff out on my own, but I'm about to pull my hair out over this drivetrain slop I have. I'm looking for any additional input before I dive into the idea of replacing my trans completely...
Current symptoms:
-On/off throttle slop
-More apparent in low gears (all gears have this)
-Audible, but not insanely loud clunk in the center/rear of the car. Can be heard in cabin
-Fairly certain the slop is rotational in the driveline rather than a mount
Attempted solutions/Current aftermarket parts:
-034 Street density motor mounts
-2.8 transmission mounts with grade 8 hardware (nylock nuts)
-ECS poly rear diff mount
-Window welded rear diff brace bushings (not that they were cracked before anyway)
-034 center driveshaft support bearing
-Brand new replaced GKN driveshaft CV joints
-Fully refreshed rear axles (tear down, regrease, new boots)
-Apikol poly snub mount
-Recently rebuilt 1-2 collar and 1,2,3,4 synchros
-Replaced rear diff with another used unit
-Replaced center diff with another used unit
-Fresh Redline trans fluid
-Fresh Redline rear diff fluid
Even after all that, I'm still having this issue. It makes having a stage 3 car a bummer to drive when all you can think about is that clunk and how you can drive differently to avoid it
So, I'm at a point where I think it might be internal to the transmission for one reason or another. The slop was there before and after I rebuilt the collar/synchros. If anyone has any other suggestions I can try before pulling the engine yet again, I'd appreciate it. Hopefully this will help someone else down the road at some point
Car in question (save the "bags are stupid comments") since everyone likes pictures:
