Good day!
Clutch Masters Single Mass 22lb Steel Flywheel
FX350 Clutch Disc/Pressure Plate (think stage 3.5)
The entire setup has about 9k miles on it. You can see everything looks great, no unusual wear or hotspots!
I've never launched it. Engagement is kinda abrupt after the disc gets warm. It does shudder. I didn't really like it around traffic and such but it held my power just fine. 400+whp 380+wtq. If you're like me and very rarely drive the car in heavy stop and go then go for it.
The reason for sale is the pilot bearing failed, which is held by a snap ring in the center of the flywheel (see pics) and i wanted to upgrade my whole setup anyway for more booooooost. No big deal, i removed the bearing and tossed it in the trash. It takes a minute to replace. There is no damage to the bearing bore. It cost about $30 for a replacement bearing, which you can get from Clutch masters.
You can also use any disc you want with this if you'd like . They run about $320 for the 300series from Clutch Masters. This is a great way to save some coin compared to every other clutch and flywheel kit out there.
PRICE: $900+ship (should be about $50)
IMG_20160703_102122.jpgIMG_20160703_102141.jpgIMG_20160703_102214.jpgIMG_20160703_102223.jpgIMG_20160703_102229.jpg
***SCROLL DOWN FOR MORE PHOTOS***
