Results 1 to 9 of 9
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    Someone who knows springs please help.
    I'm trying to figure out the spring rates for two sets of springs or which ones are More aggressive/stiffer
    Tein & neuspeed
    I know progressive spring rates are very washy.
    I think the neuspeed are progressive?
    And tein are linear ?
    I've searched the tein a lot and either I'm stupid or it's hard to find info on that Particular spring.
    The neuspeed I believe are less aggressive then the tein.
    I have tein springs I believe there s tech race?
    They have a number on the brown sleeve on them
    Tein spr01-011350
    (No other markings)
    And
    Neuspeed
    55 02 25 F
    Made in Germany
    If someone could chime in would be appreciated
    Thanks
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    A little info on the Tein in this thread: Clicky click®
    Nov 03 2012
    California/so cal
    Thanks for reply.
    I think these are for tein coilovers in the link you provided.
    I think the race/s-tech springs are different?
    I know the coil has much smaller diameter on the outside and gets larger in the center. Not too sure if the coilovers are like that too hmm
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    Quote Originally Posted by Osher67 View Post
    Thanks for reply.
    Google returns that part number with a few dead-threads on non-Audi applications.
    It definitely sounds like they're progressive springs; intended to be a jack of all trades, but master of none. Take a good look at them and see if they're authentic following this guide: Tein Counterfeit
    Ed
    why say lot word when few word do trick.
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    I have Tein coils on my sedan (green color, no idea what type, came with car) and neuspeed sport on my avant.
    Neuspeed is progressive but it's stiffer than the Teins, the Teins feel like a factory suspension spring rate compared to the neuspeed.
    Nov 03 2012
    California/so cal
    Quote Originally Posted by elewsader View Post
    This never crossed my mind that they maybe not authentic I will have to look at other side to make sure there's no other markings. I had passenger spring off of car.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Nov 03 2012
    California/so cal
    Quote Originally Posted by chad99 View Post
    One thing that was getting me was that the teins coil is clearly thicker then the neuspeed springs I have I will take a picture of comparison later today.
    Thanks for reply
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Nov 03 2012
    California/so cal
    So I was looking and I must have been looking wrong
    The neuspeed is 1mm thicker then the tein
    Going to try them see how it gose.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Feb 12 2008
    Michigan
    I had the Tein s type springs with oem sport shocks and they where nearly smooth as stock, switched over to h&r/bilstien and ride became much more harsh and body roll reduced substantially.
    The Tein springs rode lower the the h&r and softer, I liked them, never bottomed the suspension out either, in my wagon. Car was too low to drive around Michigan so I had to lift it
