Results 1 to 25 of 25
    Oct 02 2005
    The Moon
    Officially crazy, 17's installed.
    Just to address the obvious, my old wheels look waaaay cooler.
    Now that that's out of the way, I love these things!
    Wheels are 17x8 et45 Kosei K5R, wrapped with Conti DW Extreme 255/40/17.
    Sub 40lbs per corner with 255 wide rubber, MUCH smoother ride vs the 18s with 245/40 tires, and my god THE TORQUE!!! Its like I put another JHM tune on top of my tune.
    Car pulls much harder due to the slightly smaller diameter of the tires, effectively changing the gear ratio and being very light. Feels like I added 20ft/lbs wtq.
    Love it or hate it, I did this purely for maximizing the cars performance. Now I need to adjust the height of the car and put some spacer on it. Need a 5mm up front and a 10 rear for a flush fit.
    FYI, 255/40/17 fit with plenty of room left over. With the right offset a 265 tire would fit without rolling fenders.
    Oct 02 2005
    The Moon
    Quote Originally Posted by chris@fifteen52 View Post
    And our 17x8 and 17x9s clear the S4 brakes.
    Oct 02 2005
    The Moon
    Well just putting it out there that there are some new 17s that clear the S4 brakes.
    And don't worry about the RS4/RS5 brake template I posted in your other thread.
    I don't think thread jacking to promote your products is very professional. It wasn't even a reply to my post, only for self advertisement.
    I already had the templete, and that hardly excuses your actions.
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Congrats on acheiving your goal and adding to the wealth of info to the platform. Never forget all the old muscle used to run on 15's.
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Glad you're happy with them! Were you on Konig flow formed wheels before? I'm looking into those and was wondering if anyone here had used them. Seem like excellently priced light and strong wheels
    Oct 02 2005
    The Moon
    Quote Originally Posted by pwest15 View Post
    They don't clear stock brakes so I passed.
    Sep 15 2013
    2017 S3
    Quote Originally Posted by p3u View Post
    Seriously? Which model? I was gonna buy the rennform and maybe put 5mm spacers on them
    Sent from my potato
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    sweet 17s and slicks coming soon!
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    I actually like them - make the brakes look bigger too!
    There is a modded b6 s4 goodwood avant at the golf course I play at - such a cool color...
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Very cool man. A 265/40/17 is closer to the stock 235/40/18 than my 265/35/18s. Going to a bigger sidewall tire will absorb more impacts so it should ride smoother on 17 inch wheels than with 18 inch wheels.
    It looks like he deleted his posts from this thread and the other one. Interesting how the sponsors can manipulate their posts like that.
    Quote Originally Posted by SprintBlueWorld View Post
    Some still do.
    Quote Originally Posted by q_dubz View Post
    Come on man. Make some passes on street tires with a full interior at a dragstrip already! I really want to see how your car does.
    Feb 12 2016
    Europe
    Want to see my 16" ?
    http://i.imgur.com/GT6wZKj.jpg
    Oct 02 2005
    The Moon
    Quote Originally Posted by Ovi789 View Post
    16's won't fit an S4, soooooo no.
    Sep 22 2009
    16's won't fit an s4, soooooo no.
    hahahahaha
    Feb 12 2016
    Europe
    Only until i get tyres for my 18" TI
    Sent from my iPad using Audizine mobile app
    Veteran Member Four Rings event's Avatar
    Jun 21 2009
    OR
    You're a dickhead and your butt dyno is broken...
    No longer my "DTM" S4
    Rolling STOCK B8.5 S4 for over a year and happy!
    Oct 02 2005
    The Moon
    Quote Originally Posted by event View Post
    Impossible, my butt dyno was recently SAE calibrated to be within +/- .3 hp.
    Not to mention going to a 255/40/17 is the equivalent to changing the final drive from 3.53 to ~3.63 and losing 20lbs of rotational mass count for something...
    Aug 09 2012
    Bay Area
    Can't imagine all the probes SAE had to insert to calibrate your butt dyno
    Sep 15 2013
    2017 S3
    Maybe it should be metrically calibrated?
    And yeah, those lighter wheels and tires and smaller rotational diameter have to count for something
    Quote Originally Posted by Kambesama View Post
    Oct 02 2005
    The Moon
    Its a sealed unit, bluetooth calibration.
    Established Member Two Rings B5man17's Avatar
    Jun 24 2013
    MN
    About time more people join the 17" club.
    Catless DPs, Magnaflow CB, 034 rear sway and end links, tint 20%, enkei ts9 pss (summer), BBS SR with R2 snows(winter), JHM R1 clutch and flywheel, JHM shot shifter, JHM shift knob, JHM tune, ohlins coilovers, stub trans and rear diff mounts.
    Oct 02 2005
    The Moon
    Quote Originally Posted by B5man17 View Post
    You're rocking 17's? Post them up!
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by JimmyBones View Post
    Some still do.
    Oh don't worry I plan to. Remember I put a new clutch in so it'll be a little while. Damn 1k mile break-in
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    have you adjusted the computer so your speedometer and odometer are correctly read? i've never done it, but it's probably easy with ODIS or VAG-COM.
    - emilio
    Jun 21 2009
    OR
    And now you're funny and sensible. You're like an onion.
    Established Member Two Rings GTM Bandit's Avatar
    Aug 23 2014
    New York, NY
    TSW 17x8 on a 2009 S5v8
