Results 2,401 to 2,440 of 5210
Threaded View
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    **OFFICIAL** Life Beyond Stage II: the higher stage development thread
    Hi all,
    Lets start a new thread as the previous one was getting pretty cluttered. This post will simply be about sharing set-ups, experiences both good and bad with the set-ups, provide great information for those who want to venture into this new arena of stock S/C power, and a questions/answers type thread. Dyno sharing, photo's, logs, and 1/4 mile testing is encouraged, and 1/4 mile times will be updated on the 1/4 mile thread here as well - - - > **NEW**1/4 mile spreadsheet submit your time here
    You may see the term "pulley ratio" or "dual-pulley," and often refers to a larger crank pulley than OEM, a smaller S/C pulley than OEM, or a combination of the two to derive to a higher pulley ratio. If the pulley ratio is larger than "3.xxx" , it can be considered a stage 3 as the amount of boost/power generated at this point is like going from stage 1 (software only) to stage 2 (software/pulley) again. Essentially the higher you can get with your engine relaying positive feedback via logs of it's health, the better potential there is for performance. Higher pulley ratio's will spin the S/C faster at all RPM level's. Aside from the obvious benefits at wide-open throttle, there is more power under the curve with many reporting excellent low-end to mid-range TQ at partial-throttle settings. To get a pulley ratio, you divide the crank pulley size by the s/c pulley size; to get the maximum RPM the s/c will spin, you take that number and multiply it by your shift-points, which may vary depending on either a B8 or B8.5, and specific TCU tuning.
    A recommendation: the faster you spin the S/C, the more heat you will be generating. You should already be considering upgrading the s/c loop cooling system if you have not already, and possibly even running meth to aid in cooling the compressed intake charge.
    On pulley ratio's that hover near 3.000, I would recommend it, but you could get by without one as long as you don't push it to the extreme like I did (attend every track event and do WOT every 15-20 minutes without proper cool downs) or you run the risk of overheating your s/c coolant loop and your s/c intercooler spring a leak.
    On pulley ratios above 3.200, I would venture to say it's a requirement to upgrade the cooling. My IAT's logs in mid 90's show a big increase from start to finish with my AWE ColdFront on a 50/50 water/coolant ratio, I can't imagine this would perform consistently on stock cooling. You may be able to get away with it if you live in the northern parts of the country though, but for the sake of consistency, I would purchase one (intercooler upgrade at the very least).
    Need some cooling options?
    Killer-chiller
    Let's talk Water/Meth
    DIY stacked heat-exchanger and reservoir upgrade
    supercharger cooling techniques and options
    Lets take for example an AWE 57.55mm / KI 194mm combination that gives a pulley ratio of 3.371:
    at a 6,400rpm upshift, the s/c will be spinning at 21,574rpm
    at a 6,600rpm upshift, the s/c will be spinning at 22,248rpm
    at a 6,800rpm upshift, the s/c will be spinning at 22,923rpm
    at a 7,000rpm upshift, the s/c will be spinning at 23,587rpm
    at a 7,200rpm upshift, the s/c will be spinning at 24,271rpm
    As of right now, the census is that the blower will be out of its efficiency range above 24,000rpm, however this may be proven wrong once better cooling options become available. If the 24,000rpm rule is to be followed, then the pulley may be too aggressive if your shift points are set at 7,200rpm. If your shift points are 7,000rpm, then this pulley ratio would be ideal for maximum performance given environmental conditions, octane, and various other factors. Fueling may be an issue as you appoach the "red-zone" in the picture below so you should consider an upgraded HPFP, LPFP, and in-line booster, or a combination of either, particularly if you plan on running ethanol gas (full E85 or a blend), or run methanol injection to aid in fuel demands.
    Here is where you can find your pulley sizes (thank you AZ member whiped) ---> PULLEY SIZES
    Blackstone analysis of a non-damped pulley (thank you Mat@1975) ---> Dampened-Undampened-Crank-Pullley-comparison-Wear?
    Need tips/tricks for installing a pulley? (thank you bhvrdr) ---> DIY-The-guide-to-30-minute-crank-pulley-installation-go-stage-2-or-2-in-a-jiffy
    The above picture shows the area where you may need to grind, or simply use a 6 rib belt instead of the standard 7 rib belt to avoid grinding.
    here is a live example of what you will need to grind ---> PIC OF AREA TO GRIND
    If you need to grind, you can simply file it down using a tool similar to this:
    Stanley makes a product that will help you with it - - -> Stanley Grinder Link
    I'll let others chime in for their results and set-ups. Log sharing is appreciated so others can make an informative choice, however I do understand that many tuners do not light it when logs are publicly shared, so keep that in mind as well because we want tuners on our side in order to take the risk and venture into this arena.
    Here are some more installation tips/tricks:
    CLICK ME Install tips/tricks
    NEED A BELT SIZE?
    Supercharger Belt Size and Part Number Thread
    Sparkplugs / gap information:
    NGK replacements PFR8S8EG (gap .022" - .028")
    NGK "one-step colder" NKR9IEX (gap .022" - .028")
    You will have to play around with your gap to find what feels best and looks the best in logs. Keep in mind that you want to run the highest gap you can get away with for maximum spark efficiency.
    OEM replacement crank bolts are: OEM bolts are M8x25 with a 1.25 pitch but 10.0 tensile
    ** this first post will continually be updated as we receive new information. Keep in mind that this thread was started near the beginning of "beyond stage 2" development where there are some unknowns. **
    Last edited by Loe; 08-26-2018 at 05:28 AM. Reason: Since the discussion has progressed beyond pulley ratio's (turbo's), I thought it'd be best to change the subject line
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
