Page 1 of 10 123 ... LastLast
Results 1 to 40 of 380
    Established Member Four Rings whiped's Avatar
    Apr 05 2016
    Portland, OR
    Let's talk Water/Meth
    This is intended to be a living post, I will update it with information as I have it.
    There are a few of us experimenting with Water/Methanol Injection(WMI) now so I figured it was time to consolidate information.
    Overview:
    FAQ: (Source)
    Code:
    Is it safe to spray water methanol injection through my supercharger?
    Yes, its safe to spray water methanol injection through your supercharger. We have set up hundreds of systems for customers over the years who are doing just this. Furthermore, you can find countless others on the internet who are doing the same with competitors systems. Spraying through the supercharger is extremely effective way of cooling off the supercharger and its rotors and housing. So much that if you are familiar with how hot your supercharger is after shutting of the car just after normal driving. If you ever get the opportunity to watch your car dynoed in person. After they finish a pull. Walk over and cautiously place your hand on the supercharger. It will feel warm to the touch and sometimes almost cool. Where as without the water methanol injection, you wouldn't be able to touch it! I have found this to be a quick and easy way to tell if the water methanol injection has fired off during a run on the dyno before waiting for the data to display on the dyno's computer showing air temps. Try it out for yourself and you'll be surprised how cool your supercharger feels with water methanol injection.
    Will it hurt the bearings on my supercharger?
    No, the water methanol injection will not hurt your bearings. We have customers who have been running water methanol injection through their positive displacement superchargers, on daily drivers, for years without any issues. While we can not see inside the supercharger while the methanol is spraying. We can tell from looking at other information and signs. It appears the majority or entirety of the water methanol injection is flashing off instantly once it comes in contact with the hot rotor pack and housing. The water methanol injection is short lived and evaporates to quickly to make its way back and into the bearings.
    Will it pit or corrode my supercharger?
    No, spraying water methanol injection will not pit or corrode your supercharger. While it's a reasonable and understandable question since the supercharger rotors and housing are made of aluminum. The methanol is too shorted lived and evaporates immediately before it is allowed time to effect the aluminum surfaces. Unlike if you store methanol in a aluminum container where over a period of days and weeks it will eventually corrode and pit the aluminum.
    Will it effect the coating on my supercharger?
    Yes, for many of the superchargers, those which are not anodized, over time it will remove the thin coating on the rotors. If you were to ever remove the rotor pack after having ran the water methanol injection for a period of time. They will almost look like they have been polished. While the water methanol injection will remove this coating. It has not proven detrimental or effected the performance of the supercharger. This coating is designed to wear and will eventually deteriorate over time regardless if water methanol injection is used.
    For the most part you will want to stick with a "Stage II" kit as these allow for progressive spraying based off Boost.
    Here are the common companies listed in no real order: Aquamist, AEM, DevilsOwn, Snow, Coolingmist
    In addition to the kits above you will need some place to route the nozzle. Common places are at the throttle body spacer, intake, SC elbow and at the intake manifold.
    Installs
    Andthen: thread, Setup: AEM kit, spraying at the TB.
    Grumpy-S4: thread, Setup: AEM kit installed between the firewalls, spraying at the TB
    nsantos: thread, Setup: AEM kit with custom res mounted in engine bay, spraying at the TB
    infinkc: thread, Setup: Aquamist kit with SRM Injection Plates
    S4Matty: Who knows
    whiped: thread, Setup: AEM kit installed between the firewalls, spraying at the TB.
    k6750gsxr: thread, setup: AEM kit installed in the trunk.
    Rollin Thunder(A4): thread, setup: Snow Kit, res installed between the firewalls, pump near the secondary coolant pump(Off the other frame rail would be better for our application IMO)
    evil35r: thread, setup: Snow Kit, res/pump installed between the firewalls, spraying at the intake.
    2013S4: thread, setup: AEM kit with remote filler mounted under pass headlight.
    Mixtures, Nozzles and Settings
    Here is what AEM recommends:
    Meth mixtures:
    Mixtures 101
    Geoff
    '13 S4 - Glacier White | DSG | 034 Stage 2+ | 3.31 PR | AEM W/M | ...
    1/4 on E40: 11.374 @ 119.90 | 034 Featured User
    Aug 09 2011
    Brooklyn, NY
    Subscribed.
    '12 Audi A6 3.0T Prestige - 187/57 DP EPL
    '06 Audi A6 3.2 Prestige - Sold
    '00 VW Jetta VR6 - Donated
    '98 Audi A4 Stage 3 - Gone
    May 12 2008
    Well done.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Here is a question I have since these cars seem to adapt, even to a tune. If you change from your 93 tune to a 104 tune many people have said they have to driver the car for it to adapt.
    That being said do you have to run a meth system on all the time to see the results. Meaning you can't just have it on a switch for situations where you going to get on it and want extra power and expect to see results.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2 & TCU Tuned / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    THEN THEN THEN Rinse & Repeat!
    Established Member Three Rings FromRagsToS4's Avatar
    Jan 23 2017
    Idaho
    Where do you order your meth from and do you premix into a container and store it until you need it, or do you mix it only at the point of needing to refill? Where did you personally install your reservoir and pump?
    Nvm, found it in another post of yours:
    2014 S4 Premium Plus/Glacier White Metallic/6spd Manual/Sports Diff/Adaptive Damping Suspension/Black Napa Leather/19" Peelers/B&O Sound/MMI-Navi/Side Assist/Carbon Atlas Inlays
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by cspcrx View Post
    Mine is on all the time now. Originally the plan was to put in a kill switch on only flip it on as I need it. Coming on at 8 psi I tend to not use a ton of it.
    I've been topping off my tank every time I fill up with gas. Usually, it is about 1/2 way down.
    When I went to the track a few weeks ago I burned through 1/2 a tank in the 13(?) passes I made starting at 5 psi.
    Even when I was turning it on and off like crazy it will adjust pretty quickly. (Assuming your fuel trims aren't way out of wack like they were with my old Revo setup )
    Quote Originally Posted by FromRagsToS4 View Post
    I have a few options:
    1. You can buy cans of M1/M5 at local performance shops, tracks or auto parts stores. The best I've found around here is 5 gal pail from a local performance shop.
    2. I've reached out to local chemical companies and they can provide me a 5 gal pail of pure methanol.
    3. You can buy jugs of pre-mixed "boost juice" online or in some stores.
    4. Blue anti-freeze and heet. (Widely available but kind of pricey for what you get)
    I mix up my batches of W/M in a gallon jug then dump it into the res. This way I always know the ratio. Technically you are supposed to mix them by weight not volume. I'm lazy and just do volume.
    I keep the extra in that jug until I empty it(it might sit for a week or two at the most). I have a corner of my garage dedicated to mixing meth like Walter White.
    My res and pump are installed between the firewall. I've posted pictures before but will do more once I type up a better post.
    Geoff
    Jan 23 2017
    Idaho
    Maybe Im not reading this right, but is this showing that the IATs with spray is better/colder, but the timing is actually better without spray?
    Dec 06 2015
    Santa Clara
    Nice thread. I think meth injection is a highly overlooked mod.
    A couple items to add to the IAT aspect. From runs last weekend, 71*F ambuent, 700ish DA, all 5 runs were consistent. IATs starting at 49*C and finishing at 69*C. This is with 500cc nozzles at the TB plate and 900cc on the intake tube right after the airbox, 1400cc total.
    I can't say whether or not one way or the other makes a difference. I can say that along with the cool to touch supercharger observation by Whiped, adding a nozzle on the intake tube makes the entire tube and throttle body pretty damn cold after a hard run.
    Sent from my SAMSUNG-SM-N915A using Tapatalk
    Apr 05 2016
    Portland, OR
    My setup:
    AEM 30-3300 V2 Kit
    Snow Solenoid Valve
    ECS Boost Tap
    IABed TB Spacer (Contact Issam to make you one)
    034 90 deg fitting
    AEM has a pretty comprehensive installation guide you can find here: http://aemelectronics.com/files/inst...ns/30-3300.pdf
    I played around with different mounting locations but ultimately ended up placing it between the firewalls.
    Mounting the reservoir:
    I used some aluminum strips I picked up from the hardware store and bent them by hand.
    I sandwiched the strips behind the soundakator box in the middle of the firewall section:
    The res fits very nicely here but you will need to trim the cabin air intake a bit to make it fit correctly. I just hacked at mine with a Dremel. I then sealed it up using some random acrylic I had lying around:
    Mounting the pump:
    I relocated the alarm horn to the right of the reservoir using the bracket I made above and some bending skills. This freed up an existing standoff to use for the pump.
    Using this I then drilled a pilot hole for the other top mounting point and mounted the pump using a sceew provided with the kit. (There is a bunch of insulation behind the firewall so you aren't risking too much drilling here. Don't go crazy though)
    Installing the Nozzle:
    Pretty straight forward but I'll post a pic just because.
    Remove the TB.
    Using the Spacer figure out the orientation you want it to go.
    Install the nozzle and check fitment.
    Plug the other hole.
    Bolt the TB back on using the provided gaskets and bolts.
    Installing the Boost Tap:
    Just follow the guide on ECSs website. (I had done this before for my boost gauge)
    I just T'ed my boost tap line inside the cab to provide boost to the controller.
    Wiring:
    Refer to the AEM guide linked above for what wires go where.
    I grouped them together... Shit that stays inside the car. Shit that needs to go through the firewall. (I redid this to wire in a solenoid after the fact)
    Remove the ECU and run the wires that need to go through the firewall that way. Using a coat hanger or some other contraption force the wires through the self-sealing gromet on the edge of the ECU box. Zip tie the wires down the ECU will still fit.
    Now run the wires to everything they are supposed to go to.
    I used the open terminal for the battery positive:
    The main ground for the negative:
    Piggy backed the soundakator fuse for the switched ignition controllor power. (I don't have a pic because my fuse box is a mess and would just confuse you) You can add a switch here to kill the system.
    Then plugged everything in and mounted the controllor in an accessible but not noticiable spot. (Near the ODB II port)
    Now follow the test procedure to make sure everything is working correctly, button everything up, add more zip ties than you think you need and you are done.
    Extras:
    If you are feeling creative you can install a flow sensor and wire it to the P3, I forgot to run a wire for it and have been too lazy/buzy to add it.
    I'll post some interior pictures later. I don't have them handy currently.
    Geoff
    Apr 05 2016
    Portland, OR
    That was my old tune that would bog when I started spraying due to massive corrections of fuel trim.
    This was with my Revo pump tune with the CW stacked 7-1 running E30. Fuel trims were 20+% and would bog when spraying.
    My 034 tune loves the meth and I am not even tuned for it. Spraying I see a massive drop in IATs and a 2+ degree increase in timing. (Increased timing, less knk)
    @nsantos, thank you for the info. I think I will step up to the 1000cc nozzle sometime in the near future. I'll run my setup as is on the dyno/track tomorrow.
    Also, post pics and I'll add you to the cool kid list.
    I heat wrapped my whole intake tube as it would get hot from the engine. It is cold to the touch as is the SC after a few pulls.
    If you let it sit for a while it will heat up though. Perhaps it is time for a KC setup for the staging lanes
    Geoff
    May 12 2008
    Why set the kit to shut off before peak boost? I assume you're making more than the 16psi the flow stops at. Is it to prevent a post-shift bogging issue?
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by theweebabyseamus View Post
    After 16 psi it is spraying at max.
    FWIW I usually see around 22-23 psi.
    Geoff
    Jan 23 2017
    Idaho
    Great thread! Favorited and will probably copy this setup after going DP.
    May 12 2008
    Quote Originally Posted by whiped View Post
    Now I get it.
    What psi were you seeing on regular stage 2?
    Apr 05 2016
    Portland, OR
    Now I get it.
    18-19 with the CTS pulley.
    The only downside to spraying is it makes the SC quieter lol.
    Geoff
    Established Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Nice thread Geoff!
    I was contemplating running meth injection last year, but decided against it. Now after seeing matts crazy mph I'm thinking I will go ahead and add it this summer along with headers
    Sent from my iPhone using TapaMilf
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jan 23 2017
    Idaho
    Any dyno charts of what 22-23psi looks like on your car?
    Apr 05 2016
    Portland, OR
    Hopefully tomorrow. 21lbs netted me 415awhp, I've posted the graph before. You can also check out my virtual Dyno thread, I'm curious how close it will be.
    Also... Did this:
    Logs look... AWESOME.
    Code:
    STAMP Engine speed Accelerator position Engine torque IGA_AD_1_KNK[0] IGA_AD_1_KNK[5] Ignition angle: actual Intake air temperature Intake manifold pressure: absolute Lambda probes actual: bank1 RFP_AV
    230.17 1976 36 388.7813 0 0 21.75 37.5 1290.53 0.9141 12.28
    230.35 2097 52 534.25 0 0 18.375 37.5 1798.73 0.7725 0
    230.52 2242 75 558.9063 0 0 18.75 37.5 1879.49 0.832 0.28
    230.7 2308 80 564.4688 0 0 19.5 37.5 1903.54 0.791 1.1
    230.88 2438 90 569.4063 0 0 21 36.75 1931.15 0.7744 3.05
    231.06 2578 91 574.0938 0 0 21 36.75 1931.23 0.7627 6.74
    231.24 2707 91 571.25 0 0 21.75 36 1911.83 0.7451 9.66
    231.41 2834 91 575.3438 0 0 21.75 36 1927.33 0.748 9.66
    231.58 2906 91 576.4063 0 0 21.75 36 1931.07 0.7813 11.66
    231.76 3034 91 576.125 0 0 21.375 36 1931.73 0.7852 12.89
    231.95 3166 91 588.0625 0 0 21.375 36 2021.2 0.792 10.95
    232.13 3321 91 587.6875 0 0 21.75 36.75 2086.37 0.8066 9.31
    232.31 3476 91 590.3438 0 0 21.75 36.75 2173.6 0.8135 7.36
    232.49 3566 91 593.4063 0 0 21.75 37.5 2253.53 0.8291 6.23
    232.67 3706 91 601.6875 0 0 21.75 38.25 2266.47 0.8125 6.54
    232.86 3850 91 613.6563 0 0 22.125 39 2282.64 0.8164 6.64
    233.04 4006 91 586.7188 0 0 22.5 39.75 2249.97 0.8135 9.1
    233.23 4163 91 615.625 0 0 22.5 40.5 2292.92 0.835 6.84
    233.41 4311 91 623.2188 0 0 22.5 42 2314.31 0.8369 6.64
    233.59 4378 91 637.9375 0 0 22.5 42.75 2340.35 0.833 5.41
    233.78 4539 91 637.9688 0 0 22.875 44.25 2392 0.835 4.18
    233.96 4673 91 644.3125 0 0 22.875 45 2412.73 0.8193 3.56
    234.13 4832 91 659.0313 0 0 22.875 45.75 2417.96 0.8291 1.51
    234.31 4988 91 644.0938 0 0 23.625 46.5 2432.55 0.8271 0
    234.5 5081 91 645.0625 0 0 23.625 47.25 2452.95 0.8242 0
    234.68 5211 91 657.1875 0 0 24 48 2450.54 0.8242 0
    234.87 5378 91 673.8438 0 0 24.375 48.75 2441.84 0.8252 0
    235.06 5506 91 663.4063 0 0 24.375 48.75 2448.14 0.8154 0
    235.25 5701 91 671.25 0 0 24.375 49.5 2450.46 0.8145 0
    235.43 5802 91 670.8125 0 0 24.75 50.25 2428.41 0.8174 0
    235.62 5961 90 669.6563 0 0 25.125 51 2440.35 0.8223 0
    235.81 6076 90 693.2813 0 0 25.125 51 2425.09 0.8291 0
    236 6149 90 667.9375 0 0 25.5 51.75 2408.92 0.8369 0
    236.18 6279 90 682.6563 0 0 25.5 51.75 2411.91 0.8398 0
    236.37 6395 90 662.5938 0 0 25.875 52.5 2423.76 0.8379 0
    236.56 6530 90 637.8125 0 0 25.875 53.25 2422.27 0.832 0
    236.74 6654 90 613.625 0 0 26.625 54 2441.34 0.8525 0
    236.91 6756 90 605.375 0 0 26.25 54 2413.98 0.8574 0
    237.09 6836 90 558.625 0 0 26.625 54.75 2423.68 0.8652 0
    237.28 6948 90 536 0 0 27.375 55.5 2412.65 0.8506 0
    237.46 7077 90 490.6875 0 0 27.375 56.25 2414.81 0.8477 0
    237.65 7227 90 476.1563 0 0 27.75 57 2344.58 0.8145 17.82
    Geoff
    Apr 05 2016
    Portland, OR
    Second pull shortly after... Those IATs though
    Code:
    348.31 1949 65 543.9063 0 0 17.25 36 1799.31 0.7939 0
    348.49 2002 78 551.9375 0 0 17.625 36 1836.87 0.7861 0
    348.66 2124 80 565.8125 0 0 18.375 36 1881.98 0.791 0
    348.85 2240 91 569.8125 0 0 19.5 36 1908.6 0.7969 2.79
    349.03 2360 91 571.625 0 0 19.875 35.25 1913.9 0.7959 5.2
    349.21 2426 91 569.3125 0 0 21.375 35.25 1912.33 0.7637 7.82
    349.39 2524 91 567.5 0 0 21.375 35.25 1908.51 0.7705 9.61
    349.57 2648 91 570.5 0 0 21.75 35.25 1907.43 0.7754 11.36
    349.75 2754 91 572.375 0 0 21.75 35.25 1912 0.7891 12.28
    349.93 2868 91 576.4063 0 0 21.75 35.25 1920.2 0.7988 13.61
    350.11 2922 91 576.5313 0 0 21.75 36 1927.92 0.8037 14.33
    350.29 3027 91 580.25 0 0 21.75 36 1949.64 0.8047 15.05
    350.48 3147 91 584.6563 0 0 21.75 36 2030.4 0.8086 13.36
    350.67 3267 91 589.8438 0 0 21.75 36.75 2087.45 0.8232 11.87
    350.85 3398 91 585.875 0 0 21.375 37.5 2157.85 0.8359 9.82
    351.03 3553 91 586.6875 0 0 21.75 38.25 2223.18 0.8389 8.07
    351.21 3621 91 595.75 0 0 21.75 38.25 2246.07 0.8262 8.02
    351.38 3720 91 589.0625 0 0 21.75 39.75 2259.75 0.8154 9.2
    351.57 3853 91 577.875 0 0 21.75 40.5 2248.81 0.8184 9.72
    351.75 3968 91 579.375 0 0 22.125 41.25 2265.72 0.8301 9.2
    351.93 4101 91 595.1875 0 0 22.125 42 2286.12 0.8311 8.59
    352.11 4222 91 604.7813 0 0 22.5 43.5 2302.87 0.8281 7.82
    352.28 4275 91 634.625 0 0 22.5 43.5 2331.14 0.8291 6.95
    352.46 4415 91 626.2188 0 0 22.5 44.25 2345.49 0.8096 7.15
    352.63 4530 91 624.7188 0 0 22.875 45.75 2365.97 0.8242 6.08
    352.81 4662 90 630.8438 0 0 22.875 46.5 2399.8 0.8271 4.79
    352.99 4733 90 645.75 0 0 23.25 46.5 2414.48 0.8398 2.95
    353.18 4857 90 650.5625 0 0 22.875 47.25 2452.29 0.8281 1.72
    353.37 4975 90 681.8438 0 0 23.25 48 2457.76 0.8145 0
    353.55 5104 91 663.6875 0 0 23.25 48.75 2462.57 0.8145 0
    353.75 5221 91 663.7813 0 0 23.625 48.75 2447.14 0.8145 0
    353.93 5354 91 659.5938 0 0 23.625 49.5 2473.6 0.8223 0
    354.11 5477 91 680 0 0 24 50.25 2464.31 0.8281 0
    354.28 5523 90 672.4688 0 0 23.625 50.25 2470.78 0.8154 0
    354.47 5650 91 705.4375 0 0 24 51 2460.33 0.8135 0
    354.65 5760 91 685.4375 0 0 24.375 51 2453.12 0.8242 0
    354.83 5885 91 662.9375 0 0 24.375 51.75 2438.6 0.8262 0
    355.02 6016 91 681.8125 0 0 24.75 51.75 2434.13 0.8262 0
    355.22 6116 91 665.0938 0 0 25.125 52.5 2434.54 0.833 0
    355.39 6163 91 678.75 0 0 25.125 52.5 2427.58 0.8311 0
    355.57 6273 91 686.9375 0 0 25.5 53.25 2432.47 0.8359 0
    355.75 6388 91 679.8438 0 0 25.5 54 2441.84 0.8262 0
    355.93 6506 91 667.6875 0 0 25.875 54 2431.72 0.8369 0
    356.11 6611 91 637.7813 0 0 26.25 54 2447.73 0.8457 0.08
    356.29 6647 91 621.8125 0 0 26.625 54.75 2420.45 0.8564 0
    356.47 6760 91 594.7813 0 0 27 55.5 2426.83 0.8604 0
    356.64 6869 91 542.875 0 0 27.375 56.25 2433.96 0.8623 0
    356.82 7042 90 496.2813 0 0 27.75 56.25 2426.83 0.8486 0.08
    357.01 7086 90 491.5938 0 0 27.75 57 2440.93 0.8203 0
    357.2 7128 91 481.9063 0 0 27.375 57 2443 0.8057 0
    357.38 7247 91 222.1875 0 0 15 58.5 2283.22 0.71 17.71
    Geoff
    Jan 23 2017
    Idaho
    Wow I like it!
    Jan 23 2017
    Idaho
    Can't tell what those bolts go to. Sorry! /noob
    Senior Member Four Rings Loe's Avatar
    Aug 09 2015
    '14 Audi S5, '15 BMW 528i
    Sarasota, FL
    Great thread! I am going to link the cooling threads on the dual-pulley development thread as well.
    -Loe- ('14 Audi S5 S-tronic )
    [10.976@124.86mph | +498 ft. D/A | 3.110 PR ]
    [11.177@124.10mph | +2250 ft. D/A | 3.371 PR ]
    Technical discussions? JOIN ME!
    Apr 05 2016
    Portland, OR
    They are the nozzles. Went from 500 to 1000cc
    Dec 06 2015
    Santa Clara
    My observations on nozzle sizing:
    91 Oct on EPL 91 file:
    -1000cc was way too much, ran super rich, but IATS were nice.
    -500cc was perfect. Lambda looked good, IATS were low and timing pull was almost completely gone
    Race gas mixes on EPL race files (e85, e85 blends or 100+ Oct)
    - any size between 500cc to 1400cc seems to work. I find that about 900cc was the sweet spot. Less timing pull, and no more than 20*C delta on 1/4 mile runs
    Logging is tricky with Meth as the tank I use is only large enough for about (5) 3rd gear pulls. Here's a shot of my reservoir setup. Window washer tank from Amazon and Devils own tank nozzle and level switch.
    Senior Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    Terrific thread Geoff!
    I keep telling myself I won't add a water/meth system to this vehicle ... but the dialed-in benefits are clearly there.... Hmmm....
    Veteran Member Three Rings A.C.'s Avatar
    Sep 15 2013
    2004 GLI
    Md
    Couple questions as I am a novice on this setup. Is it worth the time and money for a DD? If it is what's avg cost for the setup? Thanks
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Apr 05 2016
    Portland, OR
    I daily mine, most the time it's not in boost so you don't consume much.
    I'm pretty sure I have around $500 into my kit all said and done.
    Dec 06 2015
    Santa Clara
    Around 500 as well, less meth refills.
    Dec 30 2015
    Sacramento, Ca
    Great thing about running meth when you're not tuned for it, it doesn't matter if you run out!
    Senior Member Four Rings s4matty's Avatar
    Aug 15 2015
    C5 stage 3 all road.
    canada
    Quote Originally Posted by BlownOne View Post
    True depending on what octane tune the person is running..
    When I was running 91 octane on 104 file and meth
    I saw up to 13 corrections during a long hwy run when I was logging and ran out of meth half way through the pull.
    I'm only running e30 now since I found a local station that sells it at the pump..
    So I don't have to worry as much about that.
    Sent from my SM-G900W8 using Tapatalk
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by s4matty View Post
    Very true and good point brotha. My statement was assuming the user was running the correct octane and not relying on the meth to boost octane, only to help cool iats.
    Sep 15 2013
    2004 GLI
    Md
    Good to know and thanks for the advice. I may consider this option just to keep the iat down.
    Established Member Two Rings flavormonkey's Avatar
    May 14 2015
    RS4 Avus Silver Pearl
    United States
    What is your take on RS4 applications? Theres a thread on DevilsOwn, but would like yalls thoughts if you have any!
    Sent from my SM-G935V using Tapatalk
    IG: @Blu_Fin_RS4 - @flavormonkey - @chakrascience
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by flavormonkey View Post
    I'm trying to convince bluebull who is local to add it to his RS4. I sadly don't know much about those cars
    May 14 2015
    United States
    Ha, DO IT, we need scientific field testing for the betterment of all things audi
    Established Member Three Rings Xplycko's Avatar
    Jan 13 2017
    01 A6 2.7t 6 Speed, Nissan Xterra, Jeep CJ7
    East Tennessee
    I have studied this subject heavily and have also contacted several builders and manufacturers regarding this mod. There are hardly any if none at all negative side effects to this mod. It creates cooler temps in the upper plenum and intake air as well and leads to a cooler denser air feed into the turbos themselves. It also lowers turbo temps. This leads to big HP gains respectively. The only downside I found from my research is this: if you only have your car tuned for a meth setup and accidentally run out of the go go juice it can cause problems and possibly damage to the engine. I was told that damage was a very low possibility though unless you were running a very heavy psi meth build. So as long as you watch your meth level its hard to find a downside.
    Sent from my ALCATEL A564C using Audizine mobile app
    Apr 05 2016
    Portland, OR
    Figured I'd update this with some experimenting I did over the weekend.
    Switch to the 1000cc nozzle, using 50/50 w/m coming on at 8psi and maxing at 24. (My car only hits 23 fwiw)
    IATs were lower and there was zero timing correction running at the track. (See logs above for an example)
    I made 6 passes at the track and consumed roughly a 1/4 gallon.
    At this point, I think I am going to switch it to using 60/40 w/m coming on at 8 and maxing at 20.
    Since I am not tuned to take full advantage of the octane boost yet the extra water should aid more in cooling. Once I get things dialed in with 034 I will request a more aggressive tune and up the meth level again
    Oh and gotta love steam cleaning
    Geoff
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Items for Sale
    Quote Originally Posted by Xplycko View Post
    We have superchargers.
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg W/Camera & sensors | Brushed Aluminum Trim | APR Stage 2+ | V1 | VAG COM | Hoen Xenonmatch Fogs | 034 Motor mounts | PSS 255/35/19 | Roc Euro | black RS4 Grille |
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Jun 21 2016
    Tampa, Fl
    My set up.
    Running boost juice.
    TB spacer 500cc nozzle
    Begin 6psi
    Full. 20psi
    2012 S4 6mt EPL DP 189/57 E85 - Meth
    1995 Supra Big Single Turbo 600hp 11.5ET (AEM)
    2004 350z Twin GT3076 E85 600hp 11.3ET ( Haltech )
    2012 Genesis Coupe PTE 5858 e85 500hp 11.9ET ( Haltech )
    2006 GSX-R 750 Track Bike
    Apr 05 2016
    Portland, OR
    Looks good.
    I'm curious if the long tubing runs for both boost and W/M will introduce a latency at all.
    FYI, there should be both constant and switched power back there making the wiring for the controller nice and easy
    My tune is pretty dialed in now, once I get my wheel fixed I can go back to logging to give you guys more information on mixtures and nozzles.
    Geoff
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
