Results 1 to 27 of 27
Thread: 3.0T's Avant
    Dec 17 2014
    3.0T's Avant
    I’ve been meaning to make a thread for a while now, but since I just went stage 2, I figured it’s about time!
    2011 A6 Avant 3.0T Prestige S-Line
    It took me 8 months to find the right car with the options I wanted. I finally found her at Carmax (of all places!) priced way below what similar cars were going for at the time. I got it in December 2014 with 24k on the clock.
    Since then, I’ve made a few upgrades:
    Clear side markers
    Custom intake system
    GIAC Stage 2+
    Valentine V1 Hardwired
    MMI iPhone lightning cable adapter with magnetic cell phone mount
    19” S5 wheels refinished in OEM matte titanium (from black optics package), wrapped in Conti DW’s
    Modified OEM Q5 roof rack
    WHEELS
    I found an unbeatable deal on a set of 3 bent S5 wheels that I had to scoop up. I then found another AZ member selling a single wheel in great condition to complete my set. I then brought them to my local wheel repair shop, who were able to straighten out the bends.
    Then to really make them special, I had them powdercoated in the same OEM matte titanium finish that comes on Audi’s with the black optics package. They came out amazing!
    Loaded up, ready for refinishing!
    Results
    RACK
    Again, I found an unbeatable deal on an OEM Q5 rack, so I picked it up. When going to install I found it was a little bit too long, so I broke out the measuring tape and dremel and got to work.
    I found that the front needed to be shortened by about 2”, and the rear about an 1 ½”. I disassembled the drivers side of the rack, measured, cut, then reassembled. The only other thing that needed to be done was shaving off one of the nubs from the inside clamp. On our cars, there are 2 indents on the inside edge of the roof rail. The Q5 rack has 3 nubs on the drivers side. Shaving off the excess nubs allows the rack to align perfectly with the C6 avant’s stock mounting points.
    Eventually I’ll get a bike rack and/or cargo box up there to make it useful. Unfortunately this is the only picture I have right now
    FUTURE PLANS
    Custom exhaust system, similar to B5BAR :-D
    H&R Rear sway bar
    Coilovers
    Tint
    Dec 17 2014
    Custom Intake
    It took me a while to find a solution that's both simple, effective, and costs less than half of other intake systems on the market for our cars.
    Supplies you'll need:
    (1) 3.5" Silicone Coupler
    (1) 3.0" Silicone Coupler
    (1) Silicone Reducer, Bend 45* 3.5"- 3.0"
    (3) 3.0" T-bolt clamps
    (3) 3.5" T-bolt clamps
    (1) 3.5" Joiner
    (1) 3.0" Joiner with tap
    (1) 8mm barbed hose fitting
    I used this website for most of my supplies: www.siliconeintakes.com
    If you use the 3.0" joiner with taps that I used (HERE), you'll also need some plugs for the additional holes that are tapped. These worked nicely http://www.amazon.com/gp/product/B00...ilpage_o09_s00.
    Siliconeintakes doesn't have an 8mm barbed hose fitting that worked with their tapped joiner, so I also sourced that on Amazon http://www.amazon.com/gp/product/B00...ilpage_o07_s00
    Using this system definitely opens up that S/C whine! I haven’t dyno’d the car to see if there’s any power gains, but comparing this setup to stock shows how restrictive the intake is from the factory. In my experience, freeing up airflow is always beneficial.
    I installed using this air filter http://afepower.com/shop/details_new...2L&&brandID=59
    It's a direct fit, and the only one I've found that's reusable for our platform. Their website states that it only fits the 3.2, but I can assure you it also fits the 3.0T perfectly. I'd recommend it to anyone looking to take on this project.
    AFE FILTER VS. STOCK
    TEST FITTING...
    RESULTS
    Eventually I'll probably paint the t-clamps black so it looks more subtle, but I've been running this setup in my car now for over a year. Never had any issues.
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    Great job, the car looks amazing. Next step should be a drop.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Dec 17 2014
    Quote Originally Posted by ichi d View Post
    Thanks man! I've done coils on quite a few of my cars in the past, but that was before the wife and baby were in the picture haha. If I drop this car, it will only be slightly to help with the wheel gap. Plus, losing the stock ride quality is something I've been nervous about, and mostly why I haven't pulled the trigger yet.
    Deactivated Four Rings
    Jun 23 2011
    I saw this car the other day and it looked good.
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Bro, looks the business there! Long live the C6.5 Avant!!
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Dec 17 2014
    Quote Originally Posted by c@@kieMonsta View Post
    Quote Originally Posted by Sales@EPL View Post
    Thank you thank you!
    Chris - you should have come over to say hi! I thought your shop was in Stratford...didn't realize it was right behind Excelerate.
    Established Member Two Rings DAYTA's Avatar
    Dec 30 2014
    Nice Avant! I would have loved to pick up an Avant to have two wagons in the family, but I've been happy with my C6.5 sedan all the same.
    Also, glad you know of XLR8 as well. I've been working with Josh and his crew for over 10 years (back when it was just Josh). They've built a number of cars for me (currently working on my NSX). I trust their work implicitly.
    Jun 23 2011
    Quote Originally Posted by 3.0T View Post
    I actually saw the car first and then saw this thread a day or 2 later.
    Senior Member Three Rings Indskyz's Avatar
    May 31 2016
    Virginia Beach
    Will your intake mod fit a 2010 A6 3.0T? Also how do you like the GIAC Stage 2 +?
    Beautiful car you have there.
    Sent from my SM-G900V using Tapatalk
    2010 A6 Prestige 3.0T
    GIAC Stage 2+ 93 & 100 Octane files
    AWE 57.55mm / JHM 179mm Dual Pulley (3.110 Ratio)
    PLM 26"x7"x2" additional HX
    Roc Euro Intake
    2.5" Custom Cat-back Exhaust w/Magnoflow Resonated X-Pipe and Mufflers
    Gutted CATs
    ST Coil Overs, H&R Rear Sway Bar
    19"x8.5 Avant Garde M590s Antique Bronze
    Spyder Tail Lights
    Mar 03 2016
    St. Louis, MO
    (1) 3.5" Joiner
    TEST FITTING...
    RESULTS
    Would this mod work on a 3.2?
    Dec 17 2014
    Quote Originally Posted by Indskyz View Post
    It will fit any 3.0T motors for sure. I haven't tried it, but I would bet with a little tweaking it would fit the 3.2 as well, since the intake tubes are interchangeable.
    Stage 2 is awesome, definitely the way the car should have come from the factory. I did a lot of research before deciding on GIAC, but ultimately went with them because I liked the idea of having the handheld program switcher, and that it comes with a 100 octane tune.
    Senior Member Two Rings Saifxnyc's Avatar
    Oct 19 2012
    Pittsburgh, PA
    You have a beautiful car. Love the intake mod makes be want to buy a wagon!
    Veteran Member Four Rings 2010A6's Avatar
    Mar 10 2015
    2017 Jeep Cherokee; 2018 S3 Nano Gray
    Albany, NY
    so beautiful
    Sent from my iPhone 6s+ using Tapatalk
    Current: 2018 Audi S3 2.0T Nano Gray / Magma Red
    Past: 2010 Audi A6 3.0T Midmight Blue / Pistachio Beige
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    Beautiful car, im new on this platform, i just got a 09 A6 3.0T sand im looking for some mods!
    Sent from my iPhone using Tapatalklk
    Veteran Member Four Rings ebi718's Avatar
    Oct 29 2011
    2009 A8 L
    Brooklyn, New York
    Nice!
    Sent from my SM-G935T using Tapatalk
    '10 A6 3.0T Quattro Avant Prestige Phantom Black Pearl Effect (Link)
    '09 A8L Phantom Black Pearle (Link)
    '13 A7 Quattro 3.0T Phantom Black - SOLD
    '07 A6 3.2 Quattro Avant S Line - SOLD
    May 31 2016
    Virginia Beach
    Did the stage 2 GIAC tune come with a pulley upgrade?
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    May 31 2016
    Virginia Beach
    Also,
    What is the barbed fitting for in your intake? are you Meth injected?
    Did you go with the dry filter or oiled filter as well?
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Dec 17 2014
    Yes it does. GIAC partnered with AWE for the stage 2 pulley upgrade. The only way to use their software is with a corresponding (serial #'d) pulley from AWE.
    Also,
    The barbed fitting is for a vacuum line. No methanol yet..though I bet it would help since this car seems to be affected a lot by heat.
    I used the dry filter. My original reason was to prevent debris or oil residue from coating any sensors. Since then I've read that these cars use MAP's instead of MAF's and there's really no harm in using the oiled filters.
    May 31 2016
    Virginia Beach
    Awesome. I ordered my intake pieces yesterday. Looking at the GIAC Tune as well. We have 100 octane locally on the pump, so I like that option as well. Really appreciate the post. Exhaust and coil overs are next.
    I'll post pics afterwards.
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Apr 12 2008
    2011 Audi A6 Avant 3.0T; Past: 2006 Audi A3 2.0T
    I have GIAC stage 2 with a non AWE pulley, and it works great. AWE overcharges for their pulley so went with an alternative. You could go with the APR or Revo pulley. A local shop near me machines their own pulleys and provides them for customers. But they haven't officially released to the public yet.
    Sent from my XT1575 using Tapatalk
    May 31 2016
    Virginia Beach
    GIAC stage 2
    What vendor did you go with to get the GIAC Stage 2? I've looked on their website and they list a dealer close to me in Richmond VA, but they are no longer in business or the phone number has changed.
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Apr 14 2009
    san mateo
    Im gonna place an order for al the pieces for the intake tomorrow,for my Avant:)
    Nice thread man
    Apr 14 2009
    san mateo
    3.0T's Avant
    Btw,i can get my hands on a brand new set of ST coilovers for a good price,what u guys think about them, i heard they are made by kw and they are very good for that price!
    Dec 17 2014
    Sounds good PM me if you have questions while assembling it.
    May 31 2016
    Virginia Beach
    Quote Originally Posted by denis silva View Post
    X2. Looking to hear the same before I purchase.
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    May 03 2012
    detroit michigan
    I'm running that AFE dry filter in my wifes 3.2 and really like it. I only bought it so I had a reusable
    filter because it was a pain to order and wait.....It fit perfect and the car seems to like it,even gave
    a little growl in the higher RPM's......How do you like it in the 3.0t?
