Results 1 to 36 of 36
    Established Member Two Rings FergusonHD's Avatar
    Aug 16 2013
    Miami
    Going k04... What supporting mods do I need?
    Looking to finally go k04... What supporting mods are needed right away, I'm looking to do the install myself
    Intercooler?
    Testpipe or downpipe?
    Tuning?
    Bov?
    I hate the sound that intakes make, sounds like a fish is having sex with Chewbacca so I don't plan on upgrading my airbox even though it's the cheapest mod... Is it okay to go k04 without it?
    If anyone has gone k04 please comment what mods you first did and survived without please and thank you
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    High flow cat + DP and tune are the only ones you need. IC depends on where you live and the temps you see.
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    See, I like the open intake. I guess to each their own. To provide all details, I didn't run it on my stock IHI, I put it on when I installed the FrankenTurbo. I don't think there would be a big acoustical difference, but there might be. Regardless I like it
    To answer your question, get a better drop-in filter and you'll be fine with your intake. I would also recommend to convert to better charge pipes and get rid of the POS sound box, which is found in your driver side fenderwell area.
    Never go BoV on these cars. They are MAF tune based, not speed density (MAP) and the BoV would come after the MAF so you would run pig rich a lot. Not what you want. The DV that comes with a K04 or FrankenTurbo is perfect for what you need.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Established Member Two Rings PyroDonkey's Avatar
    Oct 08 2014
    If you're not into a full intake system, you could get the ECS Silicone Turbo Inlet Hose and a better filter as Allowencer said. I'm not sure if that will change the sound, though. I haven't done the mod, but I'm sure another person can chime in on that. You'll for sure need a HFC/test pipe and downpipe. Intercooler and intake are recommended upgrades. You may need a clutch upgrade in the future, too (At least according to what I've read on APR's site).
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    How important is a downpipe? I dont really see the importance if you have a hfc.
    Sent from my SM-G925W8 using Tapatalk
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
    Jun 12 2013
    Not really at all. It's mostly if you want to get rid of the resonator.
    1 more thing to add to your list - proper spark plugs.
    Build Thread
    2020 A4 allroad
    NH
    A lot of times I have found them sold as a kit.
    Aug 16 2013
    Miami
    Quote Originally Posted by pierreb View Post
    Yea I live Miami so I'd need one ASAP lol
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    *Needs for optimal Ko4*
    DP
    Intercooler
    Plugs and R8 coils
    Afe Dry flow filter
    HFIP (helps reduce spool time)
    *wants*
    Fluidamper
    3" inch exhaust
    Open end Air intake (I have ECS, sounds real nice with Ko4, feel the csr breathing easier)
    GFB DV+
    Meth Kit (steam cleans engine and never have to worry about heat soak.)
    Hopes this helps.
    Oz
    Established Member Two Rings kiw1's Avatar
    Mar 29 2016
    2022 BMW X5
    Santa Monica, CA
    Agree with Oz. The FMIC is really a must for Stage 3 - most people recommend it for Stage 2! I'm also running a performance AFE filter and ECS Silicone Turbo Inlet Hose instead of an intake system as I'm also not a fan of the noise. Not sure if anyone has mentioned this but you'll also need the tuning software. Allot of people here run AWE.
    2012 A4 Avant - APR Stage 2, JHM FMIC, EuroCode Test Pipe, Front and Rear Sway Bars, Bilstein PSS10, CR15, ECS Turbo Inlet Hose, aFe, RS Front Grille
    Mar 03 2015
    Any of you ko4-ers running s3 injectors?
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    I've recently completed a K04 install on my car. I'd already accumulated quite a few parts for the upgrade prior to actually getting it and installed a few of them (i.e. exhaust and intake). I now have Eurocode FMIC with all the associated EC plumbing, 034 HFC, B&B exhaust that includes the midpipe, ECS Kohlefaser Luft-Technik intake System (sounded like $hit with the K03, but sounds much better with K04??), appropriate heat range plugs & R8 coils, APR software. I have the GFB DV+ to install, but was instructed by an APR R&D tech to abstain from it as the stock APR K04 DV works as it should with there setup, so it's still sitting in my office next to a pile of suspension & brake parts that are part of my next big project.
    I'd say that since the OP is in Miami that the FMIC & associated plumbing are a true MUST HAVE for that environment, and the HFC/testpipe & appropriate plugs/coils are requirement per just about all the K04 sellers.
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    What about clutch?!? Haven't seen any mention of it in this thread so far.
    I'm not familiar with the B8, but I know if you went K04 in a Mk6 GTI with similar TSI engine, a clutch was a must have. The factory clutch wasn't sufficient on even just a Stage 2 GTI... much less with a K04.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Jan 21 2016
    Hayden, AL
    ^^PyroDonkey mentioned the clutch. I take that for granted as mines an 8-sp Tip
    Thanks,\
    Ed
    Jul 10 2016
    Pueblo Of Sandia, New Mexico
    What does a automatic trans need for a K04?
    Jan 21 2016
    Hayden, AL
    ^^^ Nothing. At least if you have a 2011 or newer, I'm not sure about the 6-speed auto.
    Thanks,\
    Ed
    Jul 10 2016
    so its just a turn key turbo upgrade for 2013+ automatic models?
    Jan 21 2016
    Hayden, AL
    ^^^No. You still need the aforementioned necessities. See Oz's post.
    Fmic
    Plugs/coils
    HFC/test pipe
    Software
    Etc.
    Just no clutch upgrade needed
    Thanks,\
    Ed
    Jul 10 2016
    what kind of plugs? where do i find the R8 coils?
    Also cant figure out what is a fluidamper?
    thanks
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    Quote Originally Posted by Dez_Nutz_NM313 View Post
    thanks
    Check out USP Motorsports website for the fluidamper
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
    Mar 03 2015
    Quote Originally Posted by kwbdc View Post
    Anyone running the fluidamper? IIRC there were issues with the ECS light weight pulley? Isn't this a similiar product?
    Veteran Member Three Rings slowone11's Avatar
    Feb 15 2015
    Castle Rock Colorado
    You do not need "r8" coils or bigger injectors. Im on stock coils and ngk s4 plugs with my Loba k04 at 6000 feet altiitude. You do need hfc, fmic, hpfp, tuning, and exhaust....this is all recommended to get the full potential.
    I put down 320awhp and 360awtq i do have the fluidampner pulley.
    Sent from my LG-H900 using Tapatalk
    Jan 21 2016
    Hayden, AL
    ^^^ I don't have the HPFP and it wasn't even recommended by APR. I have all the other stuff (plus the R8 coils).
    Thanks,\
    Ed
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Quote Originally Posted by slowone11 View Post
    Upgraded coils are way more of a must-do than hpfp and exhaust. The fastest non-EFR pump gas 1/4 mile times here were run with stock hpfp and stock catback exhaust. They do nothing for performance.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Feb 15 2015
    Quote Originally Posted by NLPed68 View Post
    My loba hpfp was recommended with the loba turbo as a combo
    Jun 19 2015
    Boston
    Yeah, by the people trying to sell it to you. Sorry I don't mean to be a dick, but APR is running much more power than any of us with their EFR on bone stock fueling. None of us need a hpfp.
    Feb 15 2015
    Quote Originally Posted by lettuce View Post
    What do you mean by "much more power"? My set up at sealevel will make 50-60 more hp...that puts me close to 400awhp. What is apr putting up? And how much does the kit cost?
    Jun 19 2015
    Boston
    LOL. Do you seriously think your K04 puts out more power than an EFR 6758?
    Jun 12 2013
    More power yes, 50-60, I don't think so. Try like another 20-30ish.
    Build Thread
    Veteran Member Three Rings VNA4's Avatar
    Jun 20 2015
    San Jose
    U need 4 grand. That's it lol
    S4 B8.5 2014
    KW H.A.S. / EuroCode ÜSS Adjustable Sway Bar / AWE Touring Diamond Black / 034 Stage 2+ / DP 187mm / APR Stage II Carbon Back Pipe
    20 x 10 et35 StanceWheels SF01 [PowderCoated Diamond Black]
    SOLD
    AUDI A4 B8 Premium Plus Sport:
    CTS k04/ APR k04 File / AWE Quad exhaust / FMIC: TR8
    VIP VRC 13 : 19X9.5 / Tires: 255/35/19 / Solo werks Coilovers / OE S4 Front Brake Upgrade Kit
    Feb 15 2015
    I never said it did. I wish i would have went BIGGER.. But you make it sound like its the best kit ever made. They haven't even released it yet and you are all on its nuts.
    Feb 15 2015
    Quote Originally Posted by Allowencer View Post
    70-90 more power would be nice. 400awhp is what i was shooting for but i also was looking for quick power as i autocross my a4. My full boost kicks in at 2500rpm and pulls all the way to 6800. Im not to keen on having a highway numbers queen. These big turbo builds usually only have power from 4k-7krpm
    Jun 19 2015
    Boston
    Dude, get a grip. This has nothing to do with being on anyone's nuts or your big turbo envy and resulting insecurities. The only reason I brought up that kit was to point out that there are A4s making more power than you on stock fueling. If an A4 with an EFR can run a 12.1 with a stock hpfp then what makes you think you need an aftermarket one on your slower K04?
    I understand your shop screwed you over with promises of 400awhp or whatever, but put your emotions aside and look at it logically. You want to try to justify all the money you spent and I get that. But unless you have a setup capable of running in the 11s a hpfp is just not necessary. Sorry. If it'll make you feel better then you can keep on thinking it is, but I just want to clear things up for the other people reading this thread so people aren't running around buying shit they don't need.
    Feb 15 2015
    You're right. Its way better. I spent the money cause i broke my car not because my shop said i needed anything. Oh and when people say..."i dont mean to be a dick but" you are being a dick.
    Jun 19 2015
    Boston
    I really wasn't trying to be a dick, I swear. I just wanted to talk about car parts and then you triggered me by insinuating that I'm an APR fanboy.
    Feb 15 2015
    Ok...i apologize. My bad. Lets talk car stuff.
