So about 5000 miles ago I replaced the water pump, thermostat, thermostat housing, coolant temp sensor. Now that it has been getting really hot here in Colorado my 02 allroad has started overheating anytime I try to run the A/C. I got it into a Audi shop today and the mechanic warmed up the engine and let it idle for an hour with the A/C on without it overheating. This has to be a flow issue I'm thinking, the mechanic told me that if it only overheats while driving it maybe the radiator has build up or has a clog. By the way the A/C works really well and blows cold, no problem there. When it heats up the coolant temp goes way up and so does the engine temp. I forgot to add that it overheats a little even when im not running A/C at all. Does anyone have any ideas?
