Results 1 to 12 of 12
    Apr 22 2013
    maine
    Wiper fluid exiting front of hood
    Not sure what's going on, but sometimes when I use washer fluid I get spray shooting out from front left side of hood. I open the hood and see that it a bit wet on underside. I know car doesn't have washer sprayers for headlamps, so what else could be the cause?
    Mar 21 2015
    I think all of the B8's have headlight washers, not sure if its just the B8.5's though. You might have a cracked hose somewhere.
    Apr 22 2013
    maine
    I don't see any headlamp washers anywhere. Are you sure?
    Jan 28 2013
    Quote Originally Posted by jzinckgra View Post
    Maybe this video will help:
    Apr 22 2013
    maine
    Quote Originally Posted by Lamprey View Post
    lol, no shit! I just went out and looked and sure enough, I've got them. Learn something new everyday. thanks.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    My B8 Prem + S4s did not have headlight washers.(Thank God!). But I believe the Prestige models or the B8.5s do. IMHO, they make more mess than benefit.
    Mar 21 2015
    Quote Originally Posted by Dr GP View Post
    I agree, I hate them. Turned those damn things off.
    Apr 22 2013
    maine
    Did you use vagcomm? I'd like to turn them off as well. Seems pointless.
    Apr 05 2016
    Portland, OR
    My B8.5 P+ does have them. I did however, also turn them off.
    I did it via VCDS however, I think you can also pull a fuse.
    Geoff
    Mar 21 2015
    Apr 22 2013
    maine
    Follow up question. Are these sprayers supposed to work all the time cause I pull the trigger and nothing happens. They only seem to work first thing in morning.
    Oct 20 2008
    Denver
    they only come on with the initial wiper activation when headlights are on the ON position.
