Originally Posted by
dbv2
What you're saying doesn't seem to be matching up with the pictures you're showing or my experiences with installing this DV+ myself. Maybe there's a bit of confusion between you two as to what you're both referring to in regards to the piston and plunger?
The brass piston (metallic gold piece with the orange rubber top) is the part which the instructions say to oil, and never comes into contact with the part OP broke. The black plunger is the piece with the small o-ring in OP's picture that comes into contact with the piece of the DV+ housing that he broke. It is never specified in the instructions to lubricate this part, as it doesn't slide against anything. The only contact this part has is with the factory solenoid, and the part that broke off. See the following cutaway diagram:
(taken from this video at around the 1:08 mark (the whole video is a good watch though):
Just by going off what I'm seeing here, it looks like there was a failure with the rubber o-ring on the black plunger (completely irrespective of the brass piston). And since it seems like this o-ring not only acts as a means to seal off the underside chamber of the piston from air pressure, but also to cushion the black plunger from its contact with the part OP broke, I would hazard a guess that the lack of cushioning could certainly lead to a breakage like this, since you will now be experiencing un-softened metal-on-metal contact.
Again just going off the information I'm seeing here, it could very well be a one-off issue, but I wouldn't go around telling anyone they 'fucked up'. Especially considering he put 30k miles on this part without issue. It looks to me like this o-ring should be considered a wear item, and be replaced during servicing while relubing the brass piston.
