Results 1 to 19 of 19
    Oct 02 2005
    The Moon
    Wiring bluetooth, need a 12v source
    Just bought this off ebay to add bluetooth streaming.
    http://m.ebay.com/itm/AUDI-RNS-E-Blu...501?nav=SEARCH
    I didn't realize I had to wire the bluetooth to a 12v source.
    Any suggestions for this?
    Appreciate any help!
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    just take a multimeter and tap off the 12v for the radio.
    Oct 02 2005
    The Moon
    Quote Originally Posted by q_dubz View Post
    Thanks for the tip.
    Where exactly would I be tapping. Electrical is not my forte...
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    You want to tap into line thats being activated by ignition. Otherwise it will stay on constantly. I dont remember which one that was but just take volt meter and track it down. Or look for a diagram that will tell you which one is ignition
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jan 17 2014
    New Jersey
    If you cant find them on the radio just tap into lighter power supply, its activated by ignition plus fuse is bigger on it so you wont blow it. Thats what i did for my usb charging port
    Insta: luccamentone
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Quote Originally Posted by Lucca M View Post
    Audi OE radios don't have a switched ignition feed, they only have a permanent 12V feed.
    They switch on/off using messages sent over the Infotainment CAN bus.
    The easiest way to get a switched 12V feed (other than routing a new wire from the fuse box) is to fit a relay with the coil controlled by the switched power out from the radio to the CD changer and the contact connected to the permanent 12V.
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    My suggestion would be running off the cigarette lighter power supply, or run the line to the fuse box.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Jan 14 2007
    Hampshire, U.K.
    The disadvantage of using an ignition feed is that you won't be able to listen to streamed music with the radio on and the ignition off (Audi radios can be turned on when the ignition is off and will stay on for 30minutes) - this is why I suggested generating a switched 12V from the CD changer power line.
    Jan 17 2014
    New Jersey
    Quote Originally Posted by PetrolDave View Post
    You are correct, i would suggest cigarette lighter as well.
    Insta: luccamentone
    Oct 02 2005
    The Moon
    Sounds good. Now, how do I remove the lighter to wire it? Please don't tell me I have to remove the whole console...
    Jan 17 2014
    New Jersey
    If you remove climat control youll find it on right side of the console if i remember correctly
    Insta: luccamentone
    Oct 02 2005
    The Moon
    If that's the case awesome. Ill find out shortly.
    Thanks for everyone's help.
    Jan 14 2007
    Hampshire, U.K.
    I wouldn't (and didn't) suggest the cigarette lighter - for the same reason I already stated that you won't be able to listen to streamed music with the radio and and ignition off.
    Oct 02 2005
    The Moon
    Actually the cigarette lighter always has power in Audis, at least in the 8 I've owned.
    Jan 14 2007
    Hampshire, U.K.
    Quote Originally Posted by p3u View Post
    Which is also a problem - that means the Bluetooth adapter will be permanently powered and hence discharging the battery even when the car is parked up.
    A permanent power source is a bad idea as it discharges the battery even when not in use, and an ignition power source stops you streaming when the ignition is off; hence a power source switched by the radio (i.e. using the CD changer power output) is the optimum solution.
    Oct 02 2005
    The Moon
    You're contradicting your earlier post about being on while the ignition is off, but I understand your point.
    I'm not concerned as bluetooth is a miniscule power draw. I also own a battery tender as I infrequently drive my car.
    Jun 10 2016
    2005 Audi S4 \ 2010 Honda Fit
    Germantown, Maryland
    Outstanding.
    This sounds like a do-able project for me. Let me know how you come along and point out details of where you tapped for 12v.
    Just purchased my 2005 S4 late last week. I have a 30-pin plug that may already go to the auxiliary source. Bluetooth would be preferable though.
    Dave
    Jan 14 2007
    Hampshire, U.K.
    You're contradicting your earlier post about being on while the ignition is off.
    That's what happens when you are old
    Glad a permanent feed should work for you, but it won't for everyone.
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    Good info here: http://www.audizine.com/forum/showth...1#post11474465
    and here: http://www.audizine.com/forum/showth...1#post11480883
    The fuse I tapped into is 12v for the garage door opener and is linked to the ignition, so it only powers when the ignition is on. I used a step-down, but if you need 12v's than you cant tap right into it
