Results 1 to 11 of 11
Thread: BOV questions..
    Active Member Two Rings djtronik's Avatar
    Mar 31 2016
    Latrobe, PA
    BOV questions..
    Hey guys, totally new to the Audi scene and very excited to be here so I apologize in advance for being a newbie..
    Anyway, I bought a car off a very good friend of mine that I have fell in love with but just one small detail has changed: the BOV. So, here's the thing..up until a few weeks ago (and yes, I know the BOV has some flutter) the BOV would sound more like a whooooooosh...now, what seems to be going on is the the BOV is fluttering much more prevalent than before. I know some BOV sound exactly like this, but it's just bothering me because I want to make sure it's not connected to any issues. And I actually did prefer the whooooosh sound. I believe the BOV is from Forged.
    Anyway, things I've done..I've checked plugs, coils, etc and looked lightly over the piping (everything seems to be tight). It shouldn't be a boost leak, according to keeping my eyes on the gauage. My next culprit was maybe to check the BOV, maybe it was some bolt or something etc. but I wanted some secondary input on anything else you can think of. Thanks for your help.
    Video of current sound below:
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    i'll go ahead and be the first to let you know that these cars are not equipped with BOV's rather they have DV (Diverter Valves). You have to check and see if the PO installed a DV+ which gives these cars that sound that everyone loves to have and go from there with your troubleshooting. also, if you tripped a CEL, post the codes and help will come.
    Mar 31 2016
    Latrobe, PA
    Quote Originally Posted by miA4 View Post
    Yeah. This car is by no means stock whatsoever. There's a BOV.
    http://www.audizine.com/forum/showth...s-Build-Thread
    Oct 09 2015
    Colorado
    Its gotta be a forge dv or dv+. Its not a bov as our engines can't function properly with a bov
    Oct 24 2015
    Perth, WA
    ask your friend.
    My respray thread
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Quote Originally Posted by Okedokey View Post
    ask your friend.
    X2. Most logic indeed.
    Ivan
    Mar 31 2016
    Latrobe, PA
    Quote Originally Posted by dalmation53 View Post
    Sick logic. I asked my friend. And that's what he told me. Which is why I asked here. If I'm wrong, I stand corrected. But you're still being asswipes.
    Aug 19 2013
    Miami
    Quote Originally Posted by djtronik View Post
    I'm not being an Ass. I didn't even replied to you. Lol anyways you want help i'll help this cars will run rich on BOV's. It can be done but are not meant to vent to atmosphere. It will actually loose power. If the car dose have a BOV replace it with revision D diverter valve. I have a DV for sale for $30 if you interested with only 20k miles on it.
    Sent from my C5306 using Tapatalk
    Ivan
    Aug 09 2007
    Mount Airy, MD
    you dudes did check out his car's build thread right?
    OP, I'd say its possible surging you are hearing, and it may be a result of the spring stiffness in the BOV. As it vents, if the spring is too strong it will close prematurely causing the last of the venting pressure will push it back open, repeat, repeat, that's why it sounds like a chatter. You may need a softer spring for the summer months for the hotter/thinner air.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Jun 17 2013
    jersey city nj
    Welcome to . you will get some some great advise on here. And then you will get responses. Sykora A4 OP, I'd say its possible surging you are hearing, and it may be a result of the spring stiffness in the BOV. As it vents, if the spring is too strong it will close prematurely causing the last of the venting pressure will push it back open, repeat, repeat, that's why it sounds like a chatter. You may need a softer. has the most logical mechanical response to your question. Your gonna have to sort out the bull to get to the better experienced modders on here.
    Mar 31 2016
    Latrobe, PA
    Quote Originally Posted by SykoraA4 View Post
    Quote Originally Posted by vce1232000 View Post
    Thanks for the reassurance and the great insight. I will certainly check it out.
