Hello,
After researching and not finding complete part number listing for the timing components, I've been putting a list together myself. It is not worth it for me to purchase the components from the US at this time, I am in Canada and with (25%) conversion, shipping and duties it comes out to be very expensive. I have already purchased the JHM mechanical adjusters as those are the only things I can't purchase locally.
I know I am missing some small gaskets, if you do the know the part numbers for them, please post them so I can add them to the list. I do know that the main B6/B7 Timing thread shows the part numbers but it also shows part numbers for various gasket such as valve covers and does not show the part number for the metal guide. I want to keep this strictly for the timing components only.
Cam position Sensor Bank 1 & 2 x2 (06E905163) ** If your car has a faulty sensor the ECU is not able to properly apply ignition timing and fuel. This can lead to decreased performance, poor gas mileage, and sometimes even complete engine failure. This is optional but cheap enough to do. This is the only non timing related part I've listed.
Timing Chain (079109228D)
Timing Chain (079109229K)
Timing Chain (079109229)
Timing Chain (079109229L)
Timing Chain Tensioner Gasket (079109139M)
Timing Chain Tensioner (079109467AE)
Timing Chain Tensioner (079109507G)
Timing Chain Tensioner (079109218D)
Timing Chain Tensioner (079109217J)
Timing Chain Guide Rail (079109510M)
Timing Chain Guide Rail (079109513C)
Timing Chain Guide Rail - RS4 CORRECT GUIDE FOR S4** (059109469F) **Can someone who did their timing please confirm that this is the replacement metal guide for the common failing plastic.
Timing Chain Guide Rail (079109510E)
Timing Chain Guide Rail (079109514B)
Upper Guide Rail (079109513D) x 2
**Vin Specific
Timing Chain Guide Rail (079109469AD) OR (079109469AC)
Hardware;
2x Bolt (M12x1.25x100) (N90981001)
2x Camshaft Sprocket Washer (36x12.5x8.5) (079109497)
2x Screw (M6x35) (N10554005)
2x Bolt (M6x30) (N10156205)
4x (M6X20) (N10124306)
1x Sealing Compound (D176404A2)
Cam Chain Tensioner Gasket - Left (079131120A)
Cam Chain Tensioner Gasket - Right (079131120)
Lower Timing Chain Tensioner Gasket - Center (079109139M)
