About 2.5 hours in to the drive, it started leaning out under throttle and began misfiring. We were about 20 miles out so we pulled over for a few minutes to check things out. After shutting it off, it wouldn't start back up, it would kick for a second and then shut off. We let it cool down for almost 2 hours (the ambient temp was above 100º at this point). It started back up and ran fine again. We got back on the road, and it did the same thing, this time about 2 miles from Wüste. luckily my friend had AAA and I was able to get a free tow to the event. At the event, some of the guys were helping me with some diag and it was misfiring mostly on bank 2 (cyl 4,5,6) at idle with 5 and 6 being the worst.
Then on Sunday, I started it up and idled good, ran good, AFR looked alright at ~15 so I decided to give it a shot home. We got about 1.5 hours into the drive and same thing happened. Ended up getting a u-haul in Kingman and towed it the rest of the way home.
Summary: for those of you who don't want to read the above
Car runs fine when cooled down, then starts misfiring and running lean when the engine is warm and running for awhile. First happened when ambient temp was about 100º, was driving for 2.5 hours in sub 100º temps. When warm misfires on bank 2 the worst when idling. Starts and runs fine when cooled all the way back down
Heres a list of codes I've noted, in no particular order. Can't remember exactly when what codes where thrown at what times Ill add some as more come to mind
16555/P0171/000369 - Fuel Trim; Bank 1: System Too Lean
16558/P0174 - System Too Lean, Bank 2
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
16534/P0150 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
16514/P0130/000304 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
17649/P1241 - Fuel Injector for Cylinder 5 (N83): Open Circuit
17645/P1237 - Fuel Injector for Cylinder 1 (N30): Open Circuit
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Misfires on cylinders across the board
These are all the codes I can remember for now
Stuff Ive tried:
Swapping injector adapters -> problem still stays on injector 1 and 5
Swapping coil packs for new ones (thanks MetalMan) -> No change
unplugging maf -> No noticeable change
untucked harness wires from under intake manifold -> No change
New o2 sensor on bank 1 before problem started happening
Swapped ICM deletes -> no change
Checked grounds and voltage at ends of injector adapters
Swapped FP relay for known working one when misfiring -> no change
Swap injector 5 with inj 6 -> open circuit fault moved to cylinder 6
Compression test:
Cyl | Pressure (PSI) |
1 | 132 |
2 | 140 |
3 | 140 |
4 | 140 |
5 | 135 |
6 | 135 |
If anyone has any ideas or help is greatly appreciated. Im going to boost leak test it hopefully tomorrow
