Results 1 to 7 of 7
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Indefinite/intermediate door chime while driving.
    Driving the car the door chime will remain on forever till I pull the key, or go non stop for die for 10 seconds just to start again.
    I believe either the switch or the chime relay is going bad. The rear doors operate on those push pins things yet how do the fronts work? Is this generally just a case of replacing the chime relay or?
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    I believe the front door switches are built into the actual latch. You'll have to take the door apart to get at it and replace it. From what I've read, they are pricey to replace, but there are work around a apparently. I've been chasing a faulty switch since I bought the car. Mine was solid for months, and then we had the first really hot day of the season and it was fine. The chime went away. Very frustrating for sure.
    As for the backs, I don't have any push pins that I can see. Can you snap a pic of yours?
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
    Feb 28 2005
    Tempe
    O.k. thanks. I'll grab some pics.
    I noticed something. The chime system works otherwise perfect other then it staying on time to time.
    However the improper chime will turn off once the engine is off, and everything works fine when the car is ACC. There's only improper chime when the car is started/driving.
    Feb 28 2005
    Tempe
    Well dam, I was going to simply pull the chime relay so I didn't hear it non stop. Appears the chime is built into the cluster itself.
    Guess I'll try the door removal next.
    Feb 28 2005
    Tempe
    O.k. I'm back.
    Yes Pringe, from all I could tell the chime is built into the latch. I sprayed the switch with WD-40 and appears to help. It stopped when otherwise it'll keep going, yet haven't done the test drive yet. Doesn't look like a fun to replace as there's so much business connected to it.
    Oct 31 2015
    Victoria, BC
    Quote Originally Posted by A1 A2 German View Post
    O.k. I'm back.
    Ya, there's a ton of things to take out before you can get at it. That's why I've been leaving it for now. I've seen some fixes on a couple other forums, something about adding material to the portion of the switch that wears over time.
    Build Thread HERE
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    check the door lock switch power wires, i literally tried running a power wire to it to fix part of my electric problem the second power hit it, Even with the car running the door chime started, Just make sure there are no wires crossed in the door!
    one of those days... every day.
    Remember to change your blinker fluid it may go bad on you!
