Results 1 to 12 of 12
    Jan 15 2016
    New Jersey
    Picked up my car from the shop... headlight sensor error
    See the fix but don't feel I should fix it. Got side swiped on my way to work on the turnpike. Ruined my rim fender door and mirror. Finally got it back today (spent 15 days in a hyundai elantra) and now the headlight control sensor is messed up? Want to bring it back to them tomorrow and day fix it but I don't want to get stuck in a hyundai again... any suggestions?
    Thanks
    O and it took them 3 tries to find the correct rim.
    May 20 2010
    Increase your rental reimbursement/coverage so you don't have to. I haven't been stuck with something like that since a couple years ago when I brought my car to the dealership. Rental car closest to my preferred body shop has a deal with Land Rovers, so I'm in that. It's all up to whatever you can afford in the day.
    Jan 15 2016
    New Jersey
    Oh I'm going to. But this sensor should be on the shop and not me right? They did a great job on matching the meteor gray pearl and I might pick up some side skirts I'll want painted in which I will go to them but I want this fixed and due to it being from an accident not of my fault. And I drove the car for a week before bringing it in with this sensor not going off. They should have to cover it. Plus it failed the ball bearing test
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    It's a tiny little lever that screws into your driver's side lower control arm to gauge ride height in order to adjust your headlight position.
    Here's a picture of it I took on my car when doing my suspension. I outlined it in red for you.
    He probably just forgot to screw it back in or something. If you really hate Hyundai Elantras you can probably take care if it yourself in 10 minutes.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Jan 15 2016
    New Jersey
    That's the answer I needed. Thank you so much.
    Jan 15 2016
    New Jersey
    And oh do I hate hyundai elantras. I'm no elitest came from a Toyota yaris which is also shit. This thing was bad.
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    Quote Originally Posted by lettuce View Post
    So i wanted a better view of this sensor incase i ever had the issue and to my horror I found an outline of....well you judge for your self
    Sent from my SM-G925P using Tapatalk
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    im sorry, my inner child got me lauging my ass off at the outline. hahaha
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Lol
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    My bodyshop had to take it to the dealer to have the headlights leveling reprogrammed.
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Nice penis, bruh. Hahahaha
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    May 20 2010
    Quote Originally Posted by piotrowr View Post
    As long as they didn't pass that charge to you.
