Full fmic kit with all couplings and clamps from turbo to tb, Samco/Turbonetics methanol injection/injector and s-hose delete, lower pipes polyurethane coated to prevent pavement heat soak and are otherwise cool to the touch.
- This is for maf cars yet a map flange can easily be installed if needed.
- Fresh respray of professional grade product, yet was in a hurry and didn't prep enough and rushed spraying it. It'll look good once installed yet there are sags on the underside of the ic and you'll see it's wasn't prepped properly. The coverage is good, just used to much product and there are sags underneath.
$300 plus shipping
Meth injector seen here:
Samco S-hose $65.
Replaces the small oem tb boot (not needed for the above kit)
Blake 602-487-383eight
