Results 1 to 26 of 26
    Senior Member Two Rings czsrock1990's Avatar
    Apr 20 2010
    2001.5 Stg3 B5 S4, 2001 B5 S4
    Chicopee Ma
    Tranny?? God I hope not
    Hello all.
    So today I was driving my car and I wanted to show my buddy the car. So I took him out and was launching and as soon as I dropped it into first gear I heard a loud bang and then when the car is in gear I hear a rattle noise and the car doesn't move at all. I suspect it's the transmission because there is a clutch master 400 fx clutch in it and I can't imagine my car has enough power to rip through it and it still shifts into gear. Lmk what you think.
    Pearl White Stage 3 B5 S4
    Brilliant Black B5 S4
    2004 Dodge Ram Cummins (Sold)
    Silver B6 S4 - Milltek catback, VMR 708's, (Sold)
    Sep 09 2014
    Grand Rapids, Michigan
    Axle for sure. Inner cv joint at that
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    +1, likely an axle.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Apr 20 2010
    Chicopee Ma
    So I was wondering why if it's an axel and it's all wheel drive why wouldn't I get any power from anywhere in the car? Or is it linkage between all 4 that I messed up or something? As you can see I have a limited knowledge base with a lot of stuff. But I just figure if it was a front axel I'd still get some power from the rear no?
    Veteran Member Three Rings -Billy's Avatar
    Feb 13 2013
    Altoona, PA
    I've broken a front axle before and can confirm the car won't go in that situation. The differential just tries to send all the power to the corner that's broken, doing nothing but spinning the broken axle.
    Sep 09 2014
    Quote Originally Posted by czsrock1990 View Post
    Nope. Front and rear open diffs so all power goes to the corner with the least resistance.
    Apr 20 2010
    Chicopee Ma
    Will prob kno for sure tomorrow. I'll let you know what I see. I am hoping it's only the axle and not the tranny.
    May 16 2008
    WA
    Another vote for Axle.
    In the future if you preload the drivetrain a bit, it helps take some of the shock out of just dumping the clutch
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    I did this a few weeks ago - rear outer CV snapped and took out that corner's abs senor with it, yippie! Make sure you get OEM replacement (part out, audis4parts.com, etc.), aftermarket joints are crap
    Apr 20 2010
    Chicopee Ma
    Quote Originally Posted by wbrunner23 View Post
    Even the ECS ones are bad? I know that the advanced auto and autozone lifetime warranty ones have issues but is ECS reliable enough?
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    The Ecs ones worked well for me for about 500 miles and then the boots flew apart taking my brake lines with them.. Very scary moment, luckily I wasn't in heavy traffic. Go with oem with quality boots
    Axles aren't an area you want to cheap out on
    Oh, and that was after trying about 3 sets of autozone/oreilis axles
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Jul 07 2009
    Alberta, Canada
    Get OE remans.
    Not EMPI or whatever other junk everyone sells.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    As soon as one wheel stops registering
    movement the drivetrain stops sending
    movement to all four. I snapped just a
    front right axle and my car wouldn't move
    at all. The speedo even keeps registering
    speed like your moving but nothings happening.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by JVD View Post
    Get OE remans.
    While they are no where near the quality of OEM axles, I've had no issues with the EMPI axle I installed on the driver's side front corner for almost 20K miles.
    2024 M3 Comp xDrive
    Aug 17 2015
    Holland
    Why would you launch in in front of your friends, just to show off?
    You know that's doing alot of stress on your car, to the point where it just snaps. Was it worth it, blowing up your axle's?
    I know the B5 S4/RS4 is'nt picky on launching. The complete drivetrain just bounces up and down when hard shifting. When your launching it's doing alot of stress.
    2001, RS4 B5.
    Apr 20 2010
    Chicopee Ma
    Why do you have to judge/troll because even if I answered your question my axle is still broken. If I have a nice car with some serious horsepower I would like to be able to drive it. Others here have offered helpful advice and you have contributed nothing that I already didn't know.
    Aug 17 2015
    Holland
    Then why your doing it then? You could have saved the hassle / troubles for breaking an axle, lol. These cars are menth to be driven, not launch like a civic.
    2001, RS4 B5.
    Feb 13 2013
    Altoona, PA
    I don't know what's funnier, your sn being semen, or you saying launch like a civic. I've launched my car 100+ times easily...why? Because I fucking felt like it, and it's mine. Just relax kid.
    Jul 07 2009
    Alberta, Canada
    I store my 2001 S4 in a bubble. It's for looking at, not driving!
    Peasants...
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    I hear Raxles are good.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Veteran Member Three Rings rage385's Avatar
    Sep 06 2012
    2001.5 Audi S4, 2009 Daytona 675
    United States
    I had the same thing happen to me. +1 to axle being the issue.
    Apr 20 2010
    Chicopee Ma
    Thanks to everyone. It was the rear driver side axle. I found a guy parting a car and got another OEM one.
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Much facepalm.
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    I lost drivers front in the Lincoln tunnel at 5:30 on a Friday... Dead in the water in the MIDDLE if the tunnel with a bad axle. Had to wait on the "toter trucks ' to stop traffic and snatch me out. Quattro...
    May 16 2008
    South Texas
    Do stupid things, win stupid prizes.. +145,640 for busted axle.
    Aug 17 2015
    Holland
    Audi's are good for straight-forwards, hard acceleration, but launching is a complete different story.
    Esp when the age hits these cars, parts are worn and can blow out anytime.
    The only time my axle on my car broke, happend on a VR6 Golf when i made a small corner with not even noticable speed. It just broke and there i was standing, with no traction at all. The quattro system is great, WHEN you have traction yes. It's sick how far ESP can go when you hit grass and brakes all wheels for you just to keep the car from going out of control.
    2001, RS4 B5.
