Results 1 to 8 of 8
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    Swapping air bag Cover
    Ok as usual many have gloated on how easy the steering wheel swap is and until I got to the cover all was going great. My question is how do the cover's tabs release from the body of the bag?? There is a plate which stops the tabs from easily backing out. I saw on another forum someone cutting the tabs off but I would like to sell my old 4 spoke beige wheel with cover and not ruin it. Only spent 25 minutes before I just put it back together and took a break. Any help would be appreciated.
    Sent from my SM-G925P using Tapatalk
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
    Oct 22 2012
    Markham
    I was unaware that the covers can even be swapped, isn't that a safety hazard?
    May 01 2015
    Northport
    Quote Originally Posted by andyroxs View Post
    I've seen a post on it being done by cutting tabs from old cover on vw vortex. There are many sellers on ebay though selling used covers for our cars so there had to be a way to reuse them I imagine. Places like this [URL][http://www.airbag-covers.com/product/airbag-cover/URL] wouldn't do much business otherwise. If worse comes to worse I'll cut the tabs but the tabs on the new cover sure look to be very tight to go in.
    May 01 2015
    Northport
    I got it done, you can either bend the tabs to release the cover or unbolt the horn assembly with the three torx bolts. You will encounter the other end of the air bag harness. Just disconnect it and set it aside. You will be slowly pulling out the packed air bag so take care to keep it tightly bunched and slide on new cover.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Looks great. Thanks for the tips, I'll need em when my new cover comes in.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Oct 22 2012
    Markham
    wow, that airbag came from a 4 spoke? well done
    May 19 2016
    SWFL
    Anyone know where i can buy an airbag cover? Have a scratch on mine that kills me everytime I look at it. Need a cardamom beige one, would settle for black
    May 01 2015
    Northport
    Quote Originally Posted by mspencer15 View Post
    Selling old wheel with cover on let go....http://us.letgo.com/en/v/6812a241-55...urce=copy_link
