Results 1 to 26 of 26
    Mar 24 2016
    01 Noggy S4 09 VW CC AWD 3.6L
    westchester ny
    random bucking/hesitation
    So i have owned my 08 s4 for almost a year now. I've noticed over time that the car seems to buck when slowly accelerating at low RPM's. It sort of feels like a misfire. It happens under 3k rpm. It used to buck only once then clean up but now on occasion i can get it to do it a few times in a row. If i floor it i don't feel it happen, only seems to be a part throttle thing. If i am on the highway in 5th or 6th and want to speed up i will usually feel the hesitation then it start going. The annoying thing is the car wont throw a CEL. I changed the spark plugs this weekend but that hasnt helped. It is starting to drive me nuts. The car has 48k miles and mods are 2.25" miltek exhaust and K&N drop in filter. I've had a similar issue in a 1.8t jetta i had with hesitation at part throttle, turned out to be a bad MAF, but i am not convinced thats what it is in this car. What should i look at.
    Oct 03 2015
    West Hartford, CT
    lemme know what you find out.
    mine does the same thing, but i just chalked it up to the car not wanting to go slow...
    2015 Monsoon Grey S3
    2008 Brilliant Red S4 Avant 6MT @thatredwagon
    Established Member Two Rings JS4Avant's Avatar
    Dec 01 2014
    2004 dodge 2500
    Battle Ground, Washington
    Did you change the coil packs?
    Established Member Two Rings gaben2racin's Avatar
    Jun 15 2013
    Roseville,CA
    Vacuum leak
    Sent from my SM-G900T using Tapatalk
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Is your car an automatic?
    - - - Updated - - -
    Maybe a mount
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Mar 24 2016
    westchester ny
    Car is manual. i have not changed coil packs. I don't want to buy 8 new ones if i am not positive it will fix the issue. maybe i can buy one and move it aorund to different cylinders to see if it makes a difference. ive looked for vacuum leaks but havent found any, but i'll check again.
    May 18 2012
    2005 S4
    Portland, OR
    I started a thread about this a while back since I am having the same issue, with brand new plugs and coil packs. Logging with VCDS showed the issue was the throttle plate rapidly opening and closing at the edge of the EPC pedal range. However, it seems unusual to have this kind of behavior. I suspect a vacuum leak on my car as well as I am having random shuddering at idle only, but haven't had a chance to try to track that down yet.
    Mar 24 2016
    westchester ny
    Quote Originally Posted by 924Carrera View Post
    Has your car thrown any CEL. I wish mine would so i would have a direction to investigate.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by wstpride92 View Post
    Yeah, mine has not, which is why it's so weird. Based on the parameters I logged, it seemed like it was working correctly, but it feels extremely unrefined and I also don't remember it happening previously. Also, I have a B5 which also has EPC and it never does that.
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    mine does it too! especially around 2.5k in 2nd
    Mar 24 2016
    westchester ny
    i don't think its normal. I mean these are expensive luxury cars. For what they cost brand new i highly doubt this is normal.
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    have you tried resetting the throttle body ?
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Make sure that the 5 mm Allen bolts for the intake manifold are tight (11 Nm) and start in the middle then criss-cross your way towards the outside edges. Also make sure that the intake boot between the mass air flow sensor to the throttle body is on tight. Especially at the throttle body side because it likes to come loose.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by JimmyBones View Post
    Good tips that might help OP. However, my car was doing this thing before and after I did the valley pan job, in the process adding loc-tite to the IM bolts and definitely securing the MAF tubing. Made no difference, the car resumed the weird behavior immediately.
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Have you tried cleaning the MAF? Clean the throttle body end links maybe semi stuck?
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    I'm going through this on my car as well still no resolution in sight driving me nuts going to take it into an indy shop and see if they can smoke test for vacuum leak.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by kevinye77137 View Post
    Cleaned both the MAF and throttle body on mine, no difference.
    Jun 15 2013
    Roseville,CA
    Bad fuel filter?
    Or pump?
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by gaben2racin View Post
    Bad fuel filter?
    Or pump?
    New fuel filter on mine. Haven't replaced the pump, but I find it odd that it would not exhibit any other typical failing pump symptoms.
    Jun 15 2013
    Roseville,CA
    Have you checked your injectors?
    May 18 2012
    2005 S4
    Portland, OR
    What kind of check would you suggest? They are all seated and the car isn't misfiring, but I suppose they could still have an issue of some kind.
    Jun 15 2013
    Roseville,CA
    Plugs loose
    May 18 2012
    2005 S4
    Portland, OR
    Plugs loose
    I do have 2 injectors that sheared their locking lugs off for the plug (wonderful design....). I assumed that if the car wasn't misfiring, then the plugs were seated correctly, but perhaps I should go buy a pair of new injectors.
    Jun 15 2013
    Roseville,CA
    Well if I was working in Portland I would come n give you a hand.
    Trying to help you trouble shoot on here doesn't really help much
    May 18 2012
    2005 S4
    Portland, OR
    Yeah it's tough. I've delved into it and came up empty handed other than seeing the pedal input and throttle body response and the "flutter" happening at the edge of the pedal range.
    Oct 04 2013
    203 Connecticut
    Mine was bucking. It ended up being a vacuum leak.
    I still get the flat spots and loss of acceleration/power. I think it's pointing to clogged downpipes/cat
