Originally Posted by
Low Flyer
Hey guys, I am new to the S5 boards as I have a B5 S4 and a B8 S4. My idea is to purchase a higher mileage v8 manual and swap a motor in it....my choices are a VR6-T, LSX and boost later, a 2.7t or even an older RS6 4.2 and still retain quattro. Any ideas suggestions or thoughts would be greatly appreciated!
Welcome to the party. You're not gonna find many techs around here.. But i do love everyone. Do it! But honestly if you're gonna swap it, you could just as easily and maybe even more affordably by an A5, as you're more than likely going to be sourcing a new trans anyway. The big standoff here is factory ECU control, on any trim its a fairly intricate ECU making rewiring impossible so you'd need to go stand alone. The downfall here being any of the Audi motors you mention will require absurd rewiring hours. Once accomplished you still have the hurdle of getting the stock ecu to think the motor is still in the car so its operational with countless other features. (Im trying to broad stroke and avoid talking too much)
Once the electronics are handled, drivetrain is the next consideration. A RWD conversion won't be that difficult, and something I've been looking into. The Electronic power steering will likely need to be addressed via coding. Rear end and final drive gearing will also be a consideration. Fueling on the more modern engines will be tough but will likely work better with the existing pumps and supply but will also need to be wired in.
In short dollars for dollars and LSX would likely be the cheapest, but expect to lose a lot of the "Audi" experience. Finding a good electronics guy is going to be priority 1. Transmission and driveline priority two.
