Results 1 to 32 of 32
Thread: 2000 S4 Project
    Dec 16 2014
    Irvine, CA
    2000 S4 Project
    I was browsing the local craigslist and saw a 2000 S4 with a blown motor. Was listed at $3200, but chassis looked pretty clean, zero rust, texas car entire time. Timing belt snapped and motor was taken apart, heads were off and the shortblock had rust from being open for a year. So needs new motor. Interior was very clean, paint was good with only one tiny dent on edge of hood that can probably be PDR'ed. Car has APR Bipipe, Milltek Sport Exhaust and Stage 2 Tune of some sort. Ended up buying it for $2400, so not too bad.
    Found a a6 2.7T engine with fresh timing belt water pump and valve cover gaskets, tensioner gaskets, just redone. Going to pick it up Friday. Not sure for the goals on the car yet. I was kind of an impulse purchase. I already have a 2002 Allroad, will see how it drives with the new motor.
    Here are some pics.
    Oct 03 2015
    West Hartford, CT
    good luck, that is going to be a pretty fun project.
    2015 Monsoon Grey S3
    2008 Brilliant Red S4 Avant 6MT @thatredwagon
    Jun 08 2014
    Vancouver, Washington
    Of course theres an American flag on the back of a German car in Texas haha
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Good deal! And that interior does look minty fresh, that passenger seat hardly looks used at all.
    Sub'd.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Aug 25 2012
    Elmore alabama
    Merica. Sweet car though I feel like you got a good deal.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Sub'd ! And looking forward to see a nice and clean B5 back to live !
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Dec 16 2014
    Irvine, CA
    In the garage, started taking it apart. What a mess. Everything is coated in oil gunk. Lots of cleaning ahead. Since the heads are off, I am wondering if it is better to yank out the old motor without removing the transmission or yank it together.
    Jun 08 2014
    Together for sure. Unbolting CV's, trans mounts, linkage, and driveshaft wont take long.
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    When I pulled mine, I jerked the motor/tranny/subframe all as one. Was super easy. Just make sure to jack er up high
    2002 Pearl/onyx S4 Avant
    Dec 16 2014
    Irvine, CA
    Motor is out. While taking it apart, found the following.
    Car has H&R front swaybar, upgraded rear sway bar end links, not sure on the rear sway bar. Bilstein B6 shocks, some sort of lowering springs. Braided Stainless brake lines. AWE DTS.
    The A6 motor I was looking at did not pan out, so looking for another motor.
    Apr 25 2015
    New York
    Looks like previous owner cared for the car and put in the money to buy quality parts. I approve of everything you did btw!
    Dec 16 2014
    Irvine, CA
    Bought a new house and finally had some time to work on the car.
    Got a low mileage engine from a 2002 Allroad, but it was automatic. Engine has new timing belt, new water pump, new valve cover gaskets. It was still pretty filthy, took forever to clean the oil pan and turbos. 5 cans of brake cleaner. The oil pan is the devil when it comes to getting dirt out of the crevices.
    This is how it looked when i got it.
    Removed the SAI pump and got 034 block off plates.
    Block of Plates installed. New rear Main seal installed as well.
    Axles needed some work, they were trashed. Joints still good though, so just clean and repack.
    All taken apart.
    All clean and done!
    Clean oil pan :)
    New clutch setup. TTV Racing Billet steel flywheel and B7 RS4 clutchkit.
    Aug 24 2014
    Newport Beach, CA
    Great progress, love all the work you're doing. Amazing how much clutter the nasty SAI system creates.
    2024 M3 Comp xDrive
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    @Kaane Your project looks sweet! I'm about to pull my buddy's Allroad motor to replace his turbos. Can an OEM B7 RS4 clutch be used on a 2.7 motor? I'm thinking about getting a very similar S4 project on Craigslist to rebuild and sell it but already have two cars that need transmission work and my friend's car so it'd be too much at that point haha. Good luck finishing the car, your progress looks really good!
    Established Member Two Rings gahigalaba's Avatar
    Oct 10 2015
    B5 S4
    Western Washington
    TTV makes a flywheel that will bolt onto the 2.7t and accept a b7 RS4 clutch and flywheel
    Jul 18 2015
    Quote Originally Posted by gahigalaba View Post
    So the B7 RS4 clutch only works on the 2.7 if you have the TTV flywheel?
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    Looking good Kaane.
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by b7_Andy View Post
    Yes or another custom flywheel.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Quote Originally Posted by Kaane View Post
    Beware of the TTV and B7 pressure plate with anything other than the stock B7 disk... If you try to install a 6 puck disk, your bolt heads will likely hit. I am in the process of finding a machine shop to counter sink the bolt holes so I wont have this issue.
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Wow looks like quite the project you have going in to see how it goes!
    If you need any help looking for parts let me know.
    Thanks,
    Alex
    Dec 16 2014
    Irvine, CA
    While waiting for some parts started refinishing the headlights. They were beyond bad.
    Here is the before.
    Here is after some some work.
    Dec 16 2014
    Irvine, CA
    Took a break from the car to finally get one of these. Should be installed tomorrow.
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Man I need one of those in my garage.
    Dec 16 2014
    Irvine, CA
    Lift installed :) Moved my garage opener to the side, so now I can raise it all the way.
    Dec 16 2014
    Irvine, CA
    I think the wheel bearings are shot a bit. 3 out 4 are like this.
    Good work
    She's going to be a killer ride
    Sent from my HTC331ZLVWPP using Audizine mobile app
    May 10 2015
    Pittsburgh PA
    Great progress!
    What did you do to restore the headlights? Mine look similar to how yours did, but not quite as bad.
    S-Line converted | A7 356mm BBK | OEM 19x9" A8 wheels | Spec Stage 3+ Clutch | ECS LWFW | IE 3" downpipe | CTS catback | IEStage2+JB4 Stack Tuned | Meth Injection and more... +
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by 19birel View Post
    Great progress!
    I used sand paper to get the bad haze off about 4 different grits and then coated them with Spar Urethane mixed with mineral spirits. Fastest method for me.
    Dec 16 2014
    Irvine, CA
    Got a lot of work done. Replaced front wheel bearings. Replaced all front control arms using the FCP Kit. Dropped the engine in finally.
    Got a new battery and oil and fired it up :)
    Can't drive it yet, since I lost the snub mount bracket and waiting for it to arrive. Also the tires are shot and replacements are in the mail.
    Engine runs good, ran it with no coolant for a few seconds. Injectors were leaking from the seals, 2 of them. Grabbed new seals and should be good to go.
    Dec 16 2014
    Irvine, CA
    Got some new tires and took the car for a spin. Engine runs good, only 1 code for 1 bad egt sensor. I used nefmoto stage 1 tune and modified it for my Bosch maf and tuned out the egts.
    Finished the front suspension. Installed all new control arms.
    Rear suspension was making a ton of noise and was a mess. Car had 1 mismatched shock. It has 3 bilsteins and 1 old rusted factory shock. Makes no sense. Even the spring was rusted and the rest of the suspension has zero rust...
    Got a new spring from a friend and ordered a matching B6 bilstein shock. Rear wheel bearings were shot completely. It had also super noisy aftermarket sway bar end links. Started to take it all apart and stripped the fricking axle bolt. Had to weld a socket to it to remove it.
    Finally I got it all apart. Ordered new Meyle HD swaybar endlinks, New tie rods and new axle boots. Deciding if I want to replace all the bushings or not.
    Pressed out the old bearing and got new ones installed. No more noise, nice and tight.
    Jul 18 2015
    How's the car doing? Running strong?
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Very nice project. If you don't mind me asking, what did you pay for the A6 motor?
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
