Results 1 to 40 of 41
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    How much boost do you hold to redline?
    So a little background on my car. It's tuned for 22 psi, which it has no trouble making but it tapers down quickly to 10 psi around 5500 and up. Car has full exhaust, TP, silicon TIP, so I know that's no collapsing. Maybe this is normal, maybe it's not. What should it be at by redline?
    Established Member Two Rings pgiuliano98's Avatar
    Jun 22 2015
    Livonia, New York
    Pretty sure that since the ko3 is such a small turbo it can't hold that boost past 5500ish.
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I have an 01 a4 auto i have a stage 1 apr tune forge splitter dv and a n75 race valve spikes to 19 holds at 18 to redline
    Oct 10 2013
    State College PA
    Oh, forgot to mention I have a frankenturbo turbo manifold too.
    Oct 10 2013
    State College PA
    I did a second gear pull today and I was down to 7psi at redline. Somethings got to be wrong.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Sounds like you might have a nice sized boost leak.
    1998.5 A4 1.8TQM My Build
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Quote Originally Posted by xdewaynex View Post
    x2.
    daz said this to me when he was tuning my car: "by 5500rpm the k03s is out of juice can't even make 11psi"
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 10 2013
    State College PA
    The car boosts to 22 psi no problem lower in the rpms tho....
    Dec 10 2013
    Borden, Ontario, Canada
    About 380 to redline...
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Oct 10 2013
    State College PA
    Quote Originally Posted by Bordom View Post
    380 what?
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by Davdraco1 View Post
    380 what?
    He's posting the same lame thing in 2x threads. Canadian humor i guess.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by King_ View Post
    x2.
    did i miss where daz said "by 5500rpm the k03s is out of juice can't even make 11psi"?
    boost leak test will find your problem
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Dec 10 2013
    380 what?
    Hold on...
    Quote Originally Posted by tar View Post
    Nailed it lol
    IG: 24_et
    Sold:
    RIP:
    Oct 09 2012
    Quote Originally Posted by GrapeBandit View Post
    That was what he said after I sent him some pull logs, asking him how to get more boost.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Established Member Two Rings thrilos5's Avatar
    Feb 03 2009
    Greece
    Boost leak for sure
    Oct 10 2013
    State College PA
    These god damn Canadians! Lol. I'll do a boost leak test hopefully Monday after my tester arrives. The lady is bringing it back from home for me. Will report back as soon as I know.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    i get it
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Oct 10 2013
    State College PA
    Please explain then.
    Dec 10 2013
    Look for user redline380 lol
    IG: 24_et
    Sold:
    RIP:
    Oct 10 2013
    State College PA
    I found him, now what??? Lol
    Sep 12 2008
    South Central PA
    K03 and K04 fall on their faces past 5500 rpms.
    You can't do anything to make it better other than getting a bigger turbo. But that's a different topic altogether.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Sep 12 2008
    South Central PA
    Quote Originally Posted by RagtagXMASTER View Post
    Post logs.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Quote Originally Posted by Dan[FN]6262 View Post
    Post logs.
    Indeed.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    i would but sadly almost right after i posted the turbo in the car blew up RIP. too much bost and its dead, worst part is, its an oem borgewarner replaced about 1 year ago
    Dec 10 2013
    Lol wut? Blew up the motor in a k03? I find that hard to believe
    IG: 24_et
    Sold:
    RIP:
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    I haven't logged my new file from Motoza to view the actual data but by the gauge I spike 24 and hold 23 through most of the rev range, tapering to 22 at 7k. Hoping to get some logs in the next day or so and can post a graph. F21 MF turbo
    Sent from my LG-H815 using Tapatalk
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    No car still runs turbo is making the awful drilling sound. Much upset
    Sep 12 2008
    South Central PA
    Lies
    Quote Originally Posted by Believer View Post
    F21 =/= K03
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Oct 24 2011
    New Jersey
    Lies
    F21 =/= K03
    Never stated or implied it was. The thread title is vague and non-specific so I posted my experience.
    Sep 12 2008
    South Central PA
    How you liking that turbo? Seems like it would be a great daily driver.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Oct 24 2011
    New Jersey
    For me it is just about perfect for a daily driver. It makes boost pretty low rpm and pulls damn strong to redline. I get full request boost by just about 3k rpm and have usable boost as low as 1.8k because of the mixed flow turbine. I'd definitely recommend it!
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    [QUOTE='Dan[FN]6262;11626958']Lies
    Sadly im not lying. I loved driving my car around the way it was. Now i hate the thing. Either parting it out or sell it as is
    Sep 12 2008
    South Central PA
    Sounds like it'd be great fun on twisty back roads. What software are you using?
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Oct 24 2011
    New Jersey
    Dave @ Motoza is doing my tuning. Once I get my misfires squared away I will get some decent graphs posted to my build thread.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You hold this bike till redline?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Dec 10 2013
    Quote Originally Posted by redline380 View Post
    LOL I make so much torque, I kink all my chains
    IG: 24_et
    Sold:
    RIP:
    Oct 10 2013
    State College PA
    The intent of the thread was to see what all the people running their stock turbo hold until redline. I should have been more specific. But it is cool to see what other turbos hold to redline and where they run out of power. Still useful.
    Sep 12 2008
    South Central PA
    Full boost with my EFR is 4k, holds 30psi to 7.5k rpms.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    May 17 2014
    Raleigh, NC
    I hit 15-20psi within 3-3500k rpm, tops. Holds till I say so haha.
    Gtx2867r which should hold boost well past 22psi till redline.
    Sep 12 2008
    South Central PA
    Quote Originally Posted by rodgertherabit View Post
    I tuned a B7 running a 2867. I could get the TSFI to hold 34psi until redline, which I think was 7.5k on that engine, and made 412awhp/371awtrq on meth. They're fun turbos.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
