Results 1 to 22 of 22
    Senior Member Two Rings WEBER's Avatar
    Jul 01 2008
    Imola B5 S4 ,90 CQ 20vt KTM Superduke
    Portland, OR
    DIY: Aquamist HFS3 and custom meth tank write up
    So I've been lurking here for years sucking up info, so I figured it's time to give something back.
    For those of you who like these kind of DIY write up threads here you go.
    Using this wiring diagram as a guide, I started splicing away!
    First made a little bracket to mount the controller and have a reference of the connector lengths. I didn't take any pics of the routing under the dash but went through an unused relay spot then up through the hole in the ECU box.
    RED on the power plug and Red on the ECU plug jointed together and connected to the switched ignition power for the ECU (pin 3) at the Black with Blue stripe wire in Orange plug at the back of the ECU box. Note.... (Looking at the ignition switch wiring diagram this wire should have power while cranking and did when checking with a meter but the gauge still looks to turn off during cranking.) I still may try and find a connection at the elusive 15!!
    White and Black ground wires joined together and ran down through existing wire harness to chassis grounding point in drivers foot well under fuse box.
    Purple gauge dim Wire routed in the the rear of fuse box and spliced into the switched side of fuse 23 Grey with black stripe(Tail and side marker Left)
    Green IDC sense spliced into the Brown with black stripe wire (ECU pin 9) found in the main ECU loom, small wire buried in the middle have fun digging!!
    Brown and white wires for the failsafe. Find the Blue with green stripe (ECU pin 104) in the same area of the ECU loom, cut that wire blue/green wire in a convenient place Brown heads off to the N75 direction and White to the ECU direction
    That takes care of the all of the connections to the car wiring.
    The FAV and flow sensors come out of the ECU box and will bne mounted behind the first fire wall at a later date.
    The gauge is pretty self explanatory so I won't go into that, but here's a picture of my routing of the wire behind the cluster. I did cover most exposed metal edges with some really thick wide electrical tape as I've got my Wide-band and Boost gauge wiring in there too.
    My requirements for a meth tank were:
    -fitting driver side trunk compartment behind the factory cover without looking like a total after though.
    -must not have a flat bottom, because that doesn't make sense.
    -large capacity, this is a daily driver after all!
    -some sort of mounting points.
    Here's what I found:
    http://www.usplastic.com/catalog/ite...4794&catid=958
    I cut the top off to use one of these remote fillers
    http://www.usplastic.com/catalog/item.aspx?sku=13871
    I chopped off the top and used some tap plastics poly-weld to glue a cover over it because it had a 5" lid!
    Added some homemade baffling for the hell of it! Don't mind my sloppy fillets it's a bitch to spread nice down that little hole.
    Ill just put up some various pictures of the progress because we all have our different ways of building things, but I did only have to drill one hole for the remote filler bracket. everything else minus the relay and ground for the relay uses a factory threaded mounting point.
    Step 1.
    Mocked it up with some aluminum before making the final frame out of 1/2"x 1/8" steel bar.
    Moved the antenna thingy here.
    Step 2.
    All of the relay/pump wires were routed along the factory loom that runs from the trunk down the drivers side sill to under the dash.
    Step 3.
    The frame picks up 3 of 4 of the rear inserts. Painted with my favorite crappy MIG weld cover up, black wrinkle coat. All in all I probably had the meth tank in and out 50 times to get the mounts all nicely lined up so nothing is stressed. I can hand turn every single mounting fastener.
    Done!
    I not running the meth supply lines till the engine is out for stage 3 things, so those are not covered. Hit me up with any questions.
    I hope you have enjoyed my picture fest!!
    Justin.
    2001.5 S4 Imola
    Aug 25 2012
    Elmore alabama
    Wicked nice write up! Very I informational
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Thank you
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Awesome! Perfect timing, thanks!
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    that wiring diagram needs to be a sticky somewhere.
    Jun 14 2012
    2000 Jeep Wrangler TJ
    Tampa, FL
    wish i had this last year haha
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    wow crazy good diy we need more like this
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Love your tank setup - I hope to do something similar for mine, eventually, but I doubt it will come out as nice . Impressive.
    Jun 06 2010
    germany
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Dude! Awesome write up. Can I put this up on S4mods.com? With credit of course.
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
    May 16 2008
    WA
    My hats off to you Sir! Excellent timing!
    Jul 01 2008
    Portland, OR
    Quote Originally Posted by treysgreen View Post
    Absolutely! I'd be honored!
    2001.5 S4 Imola
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 14 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    Look nice
    Established Member Two Rings 39NAS-T's Avatar
    Jan 20 2012
    2001.5 S4 Avant Imola JHM Stage 3, E92 335xi Alpine White jb4, HPF FMIC, Custom Exhaust, BM DCI...
    Rochester, MI
    How did the Black with Blue wire turn out?
    JHM RS6R's
    JHM Tuning and Fueling
    Apikol Mounts
    Apikol Oil Cooler
    ER Intercoolers
    AR Designs 3" Downpipes
    Custom 3.5" Single Exhaust
    Factory Stock Long Block
    Jul 01 2008
    Portland, OR
    Quote Originally Posted by 39NAS-T View Post
    Works fine. If the ignition has been on and the meth is all booted up it will turn off and back on when the car is started, but I don't really see any problem with it.
    2001.5 S4 Imola
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by WEBER View Post
    You could fix that if u wanted with a dei pulse timer
    Jul 01 2008
    Portland, OR
    Quote Originally Posted by vavJETTAw36 View Post
    Yes, that would work. According to the wiring diagram there's terminal 15, which is hot even when the key is in the crank position. I'd rather find it, much less wiring. I might get to it when ever I get to adding a relay for the fuel pump.
    2001.5 S4 Imola
    Senior Member Three Rings Gtmauto's Avatar
    May 29 2016
    Ann arbor michogan
    Man you should make the tank a kit and sell it I bet people will buy it nice work looks awesome
    Sent from my SM-N910P using Audizine mobile app
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Sub'd
    What kind of performance increase did you see using this?
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by bmoreS4 View Post
    Sub'd
    My HFS-3 helped a lot. More boost and timing and way cooler temps
    Apr 27 2011
    MD
    Quote Originally Posted by gmdiluca View Post
    Awesome.
    I have a Stage 3 we built last year, trying to see what the next step is before going with bigger turbos, I've heard that W/M makes a big difference in Stage 3 cars.
    IG: @s4dad
    Jul 01 2008
    Portland, OR
    Sub'd
    I added Meth when I went stg3 so I have no before and after data.
    2001.5 S4 Imola
