More issues with my car.... I left my car at home over the weekend, and when i started it on monday, the car was in limp mode, with the EPC light on, CEL popping up shortly after that. Had to limp the car to work, No boost, rpm seemed limited and the diverter valve fluttering like crazy when lifting off the gas or shifting.
scanned the car later that day and these were the codes that popped up:
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground - MIL ON
000052 - Turbocharger Bypass Valve Control Circuit
P0034 - 002 - Low
000581 - Solenoid Valve for Boost Pressure Control (N75)
P0245 - 002 - Short to Ground - MIL ON
009217 - EVAP Leak Detection Pump Control Circuit
P2401 - 002 - Short to GND - MIL ON
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0031 - 002 - Short to Ground - MIL ON
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - MIL O
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 004 - Open Circuit - Intermittent - MIL ON
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit - MIL ON
Anyone have any ideas?
I do have a cracked ecu cover that I've been meaning to get fixed. After it rained or had a long car wash, the fan would turn on when the car was off. Im wondering if this is now causing these issues. (although it didn't rain this past weekend, nor did i wash it. it just sat on my driveway) Is there a relay or something thats gone to crap because of the broken cover relating to these codes?
Thanks in advance.
Car has UM stage 1, apr test pipe and intake.
