Results 1 to 12 of 12
Thread: 100 octane gas
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    100 octane gas
    So I don't have a tune yet but I just found a gas station within 5 miles of my house that has 100 octane pump.
    I wanted to throw some In my car but wasn't sure if it would just be a waste of money cause I'm stock.
    I thought I saw on APR's site that when they tested the stock ECU it dyno'd with more HP on higher octane fuel. If that's the case I wanted to give it a try, but I have been reading that cars without a tune won't be able to benefit from the higher octane fuel. Any thoughts?
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Senior Member Three Rings JoeCaMotto's Avatar
    May 06 2014
    Chitown
    Your car will run stronger on race gas, it will take a little for the ecu to adjust but then you will notice.
    14 White S7 Loaded
    14 HD white demin V-rod muscle
    10 White Ford Raptor 6.2 Loaded
    09 Red GT-R sold
    Established Member Three Rings HackDevil's Avatar
    Jan 23 2016
    chicago
    I have a 93 pump by my place I go to and I can tell the difference when I use 91 and I'm pretty much stock. Do it
    13 Audi A6 3.0T Prestige Oolong Grey
    Here's my: Instagram / Build Thread / YouTube
    Feb 01 2016
    Encinitas, CA
    Well just went up there, I guess they are closed on Sundays cause the pumps were locked. But they had 91, 95.5 and 100 octane, Sunco pumps. But 100 octane was $8.99 a gallon!!!!!! 95.5 was $6.99 a gallon but its nice to know when I get my tune installed I will be able to have multiple maps and have some fun with the 100 octane map!!!
    Jan 23 2016
    chicago
    Quote Originally Posted by Djpeaksd View Post
    Oh man. That's going to be some crazy outputs with a tune. Who are you going with?
    Feb 01 2016
    Encinitas, CA
    I am gonna go APR! I was considering Giac for a minute but I just feel more comfortable with APR, (probably marketing on their part). My plan was to wait til 5K sercive but not sure I can wait that long, hahaha. I have 1,500 miles right now.
    Sent from my SM-G925T using Tapatalk
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    To be honest, without proper tune for 100 octane you will feel different but that's only because your car actually supports 93 octane gas from factory so anything more than 91 will give performance gain but if you compare between putting 93 and 100 gas into your tank with stock tune, you may feel some little difference but it's more likely to be placebo so putting 100 octane gas into your tank is rather wasteful. Just wait until you are getting 100 octane tune and then put the right gas into it to so that you would gain the real benefit.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Mar 14 2016
    Cleveland, OH
    Octane is there to prevent knock or pre-detonation. I.e. you would notice no difference on a car setup for premium fuel to run 93 or 100 octane. However, with a tune that increases timing advance, boost pressure, leans out fuel trims/maps, and increases variable cam overlap you will see more of a difference between 93 and 100 octane. Since you can push the engine more since you decrease the risk for detonation. That's how you gain power with octane.
    Established Member Two Rings _SILENCER's Avatar
    Jan 14 2016
    Southern California
    There is a place near me that sells 100 octane. I pop a quarter tank of that super juice in with three quarters 91. Car runs like a rocket. It feels smoother to me, effortless as the supercharger works its magic.
    Deactivated Four Rings
    Jun 23 2011
    We will be releasing our S6/S7 software shortly and with the ability to flash at home with our cable and a laptop or we have small HP tablets that will work as well. Anyone interested in getting a deal and being an early adopter PM or email me
    [email protected]
    Do it already. I had mine done a week after I got my S7 with 500 miles on it. You'll love it.
    Sent from my SM-G900V using Tapatalk
    2016 S7 Sepang Blue HRE S101 21 x 10.5 275/30R21 Pirelli PZero. (EUROCODE) APR ECU/TCU Stage 1 VCDS Lowering . Exhaust by MAGNAFLOW
    2015 Q5 TDI Lava Gray The wife's
    2012 S5 6MT Ibis White SOLD
    Air-pressure/Load index table
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Tireguy View Post
    I know! I buckled, I made my appointment for Saturday!!!!
