It would be a good idea to drive the car until it is hot and then park it in a place where you can work on it. Let it sit overnight. Then in the morning pull the intake manifold off to check for oil pooling in the intake ports by the valves. I had leaking valve stem seals that would cause blue smoke on warm starts like when out running errands with a lot of stops where I had to drive the car a bit, shut it off for a few minutes while I got stuff from a store, then start it back up, drive somewhere else, and repeat. After a while it would blow blue smoke on the first cold start in the morning and on deceleration while on the highway.
Originally Posted by
2004B6S4
the tools are expensive and that's probably the biggest issue with doing this. I know JimmyBones has the tools though, he did a writeup over on audirevolution showing how they're used. you could send him a pm and see if he'll rent them out
I thought that my ears were burning for some reason. Yep, what you said is right.
By the way, to use the tool set the cams and timing chains for the cams have to come off so it is only a few more steps to pull the heads off at that point. Like taking the downpipes off and loosening the head bolts.
