Results 1 to 4 of 4
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    AGN oil deflector? Or, anyone have a motor with the valve cover off to see?
    My AEB camshaft oil deflector cracked one year ago and tossed it, what a mess!
    Now I'm getting ready to install my AGN I want a camshaft oil deflector. I can not find info and called ECS. The AEB deflector could work if, if it could be moved around. So:
    1) Anyone know of an AGN and/or back right corner oil deflector?
    2) If you have a motor on a stand, can you simply see if the oem oil deflector can fit securely around the back right corner area (oem location is front right corner, simply see if it can change locations)?
    Requires no tools, simply drops into place. Thanks
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Feb 28 2005
    Tempe
    That could be it, a matter if it can be be moved below the AGN valve cover oil cap (back right) to prevent oil spray.
    I believe I saw a pic one time of an AGN motor with the vc off, yet the oil deflector was in front right position like the AEB motor. I thought, "What the hell!?!? Why would Audi put a oil deflector in the front right corner when the AGN oil cap is the back right corner?"
    Maybe that's the locations where oil is possibly introduced into the head/drained on all motors in the front right corner, thus needing the oil deflector there and has nothing to do with the oil cap position at all. Or, maybe the person who took the pic had an AEB motor with an AGN vc and just left the oil deflector there when they did the swap.
    Feb 28 2005
    Tempe
    Anyone have a spare motor?
    Getting close to ECS order time.
