Results 1 to 19 of 19
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    in tribute to the V8 S4's intake manifold
    the B6/B7 S4's intake manifold is nearly 1/4 the volume of the entire engine.
    after removing the fuel rail, fourteen bolts, and every last vacuum line and connector, lifting out this massive component makes me feel like Rictus Erectus ripping a supercharger off the War Rig.
    it's the size of a small 4-cylinder engine block.
    it contains as much aluminum as Uruguay's air force.
    looking in the intake at full throttle may alert Sauron to your presence.
    - emilio
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    why the flying fuck did they make the wiring for the knock sensors so fkn TIGHT!
    Oct 02 2005
    The Moon
    Lolz, great post.
    However, I believe the manifold is made of magnesium.
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    LOL
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by p3u View Post
    Lolz, great post.
    it's an aluminum/magnesium mix. I know...i tried to weld one :\
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by q_dubz View Post
    that must have been pretty
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by jakeoboy67 View Post
    well i could get a puddle and add but it would ALWAYS crack. Pre-heating didnt help!
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Best post ever!!
    Jan 14 2009
    Audi's
    LOL I hated installing the JHM IM but so worth it after you hit the gas!!!
    Nov 12 2015
    Oregon
    LOL!!! yeah that thing can be a real PITA to remove. Ordering up some intake spacers soon!
    My build log
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by VinnysS4 View Post
    hit up JimmyBoneS4 if you want my old ones
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    hahaha
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    hah yup, felt the same way last year:
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Apr 18 2012
    Central Texas
    Quote Originally Posted by Gosser View Post
    yow, that's much further than i've ever had to go! was there something specific you had to remove the lock carrier & radiators for, or did you do it to make the belt work easier?
    - emilio
    Jun 05 2013
    Ottawa
    Initially I just wanted to fix my intake flapper, but it quickly evolved into doing more preventative maintenance; oil check valves, valve cover gaskets, auto tensioner, LW crank and belt. So yeah, mainly removed it to make my life a little easier. I could have gotten away with leaving the carrier on, but that was allowed me to do some serious cleaning.
    Oct 02 2005
    The Moon
    Of course, its an alloy. Pure magnesium is rarely used in anything.
    What were you welding it for on your turbo beast?
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    That's a lot of work for IM spacers! And a skill saw!
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Jun 05 2013
    Ottawa
    Quote Originally Posted by A4Maine-iac View Post
    ...And a skill saw!
    I couldnt get the lower rad hose off, so I had to get creative.
    2007 RS4 Avant
    Apr 18 2012
    Central Texas
    oh, jeeze, coolant hoses can be the worst. i had a very tricky time getting the hose off the thermostat housing between it sticking and the limited clearance. it was a delicate process of prying a bit away with a hose pick and then injecting some silicone oil to penetrate. it was touchy, but the hose came off intact (i probably scratched up the thermostat housing more).
    - emilio
