Page 1 of 8 123 ... LastLast
Results 1 to 40 of 306
    Senior Member Two Rings fleener22's Avatar
    Aug 10 2014
    B5 s4 stage 3
    United States
    Simple & Clean k04+ build thread
    Background- I bought this car from a member of Audizine back in 2014 8/14/14
    I snagged up the the car that weekend and instantly fell in love with the s4 power, since all I had before this were a4's.
    2001.5 Nogaro blue with 94k miles! The only thing done to the car was a blitz turbo timer. Happy I got the car stock and now doing everything myself to make it what it's becoming today.
    Goals for the car- stage 3 fun and reliable power, this will be a weekend car that will get put to use when it is drove. Also like to have this car looking the best as possible show room condition. Mainly just a fun, fast, and good looking weekend beast!!!
    Mods before turbos went...
    Engine: Daz stage 2 tune
    Arp bi pipe
    710'n diverter valves
    ssac 3" downpipes into 3" true duals
    eBay... Boost hoses
    Raceland coilovers
    Glow shift boost gauge
    Stage 3 parts/ others to install-
    Srm k04+ hybrids (On e85)
    Srm inlets
    Srm intercoolers
    Srm oil feed lines
    Srm 85mm maf
    Bosch ev14 630cc injectors (1000s after break in period)
    Walbro 450 fuel pump
    3 bar map sensor
    034 street motor mounts
    034 street tranny mounts
    034 aux coolant delete hose
    034 snub mount
    034 intake manifold spacer
    034 check valve
    Ecs gates timing belt kit
    Parts still to buy
    Clutch and flywheel setup (fx400?)
    Maf hose
    Intake filter
    Metal slave cylinder
    Gasket and seal kit
    Project b5 spider hose
    Aem afr gauge
    Before tear down
    Active Member Two Rings B5Mark's Avatar
    Jan 15 2016
    Colorado
    Looks very nice man keep this updated!
    00 Audi S4 / Stage 1
    Check out this sick B5S4 Fanpage http://www.instagram.com/b5s4
    May 16 2008
    WA
    Since you already have your motor out, you can make your own spider hose with oil rated silicone tubing instead of buying one. There are a couple threads with pictures
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by getslideways View Post
    This. Although my early style spider hose is different from the later style, use black heater core hose and the stock fittings. All in my total cost was $30.
    2024 M3 Comp xDrive
    Aug 10 2014
    B5 s4 stage 3
    United States
    Thanks iv seen a couple, I'll look into it more.
    Jul 04 2012
    Woodbridge, VA
    One thing I see time and time again is the use of regular heater hose... Sure it might work for a couple years but if it's not impervious to petroleum it will get super soft. Soft vac hoses will collapse.
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Hell yeah! I was gonna go with these turbos, but ended up with k24s instead, stoked to see how these perform
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Aug 10 2014
    B5 s4 stage 3
    United States
    Quote Originally Posted by CJ_ View Post
    Thanks!! So am I was a hard decision on whether to go k04's or k24's can't wait to see what it puts down on e85!!!
    Aug 10 2014
    B5 s4 stage 3
    United States
    Engine and trans separated
    Plan for this week-
    Clean trans, strip motor down, and get heads off.
    Aug 25 2012
    Elmore alabama
    Are you doing 2.8 heads?
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    heater hose will fuck out. dont use it.
    Aug 10 2014
    B5 s4 stage 3
    United States
    Quote Originally Posted by S4tech2 View Post
    No staying with stock heads, plan on getting them to the machine shop and getting them resurfaced, cleaned, and valve job done.
    Aug 25 2012
    Elmore alabama
    Quote Originally Posted by fleener22 View Post
    Sweet good luck with build
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by jaychen View Post
    For the spider hose?
    IG: CJ_s4
    Aug 24 2014
    Newport Beach, CA
    I used Prestone heater core hose and have no issues, as have others for years. I wouldn't hesitate to recommend it, there are pros and cons to every type of hose you could use for this application.
    2024 M3 Comp xDrive
    Senior Member Two Rings 616_S4's Avatar
    Mar 07 2016
    2001 S4
    Grand Rapids Michigan
    Those wheels!!! Love them!!!
    Aug 10 2014
    B5 s4 stage 3
    United States
    Just some of the goodies laying around waiting to be put on!
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Haha, no build is ever "simple." But on a serious note, looks good man! Good luck and will be following build.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Aug 10 2014
    B5 s4 stage 3
    United States
    Have got a lot of things done the past days. Hope to get heads taken a part and to the machine shop by Monday!
    Aug 10 2014
    B5 s4 stage 3
    United States
    More progress
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    what are you doing to the heads ?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Aug 10 2014
    B5 s4 stage 3
    United States
    Quote Originally Posted by AudiTechS4 View Post
    Cleaned, resurfaced, valve guides replaced, and valve job done.
    Aug 10 2014
    B5 s4 stage 3
    United States
    Heads dropped off today at the machine shop!
    Thought I would share a picture of my daily.
    Dec 10 2013
    Borden, Ontario, Canada
    The back is lower than the front
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    May 30 2015
    canada
    dat reverse rake hnnnghh
    Aug 10 2014
    B5 s4 stage 3
    United States
    No just had the back loaded with parts lol
    Aug 10 2014
    B5 s4 stage 3
    United States
    Got a call this morning the heads were done so went and picked them up. Very happy with the work and glad to check another thing off the list!
    May 06 2014
    Santa Fe, NM
    looks good man
    Aug 25 2012
    Elmore alabama
    Who did you use for the head work?
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Quote Originally Posted by christianb5s4 View Post
    Except when you use hose specified for the transfer of petroleum. Example would be pcv/fuel return hose, transmission cooler hose...
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by Zba View Post
    Exactly. It will get soft, gum up, and probably close shut on you. Do it right or do it twice.
    Aug 10 2014
    B5 s4 stage 3
    United States
    Local shop about 30 minutes away, I'm located in Iowa
    Aug 10 2014
    B5 s4 stage 3
    United States
    Would like some input from you guys! Im doing rings when I have the motor apart and have been wondering about doing rods and main bearings but not sure yet.
    Feb 19 2011
    Earth
    you definitely should. half the reason people don't is because they don't want to open the motor. if you're there, do it. 100%
    Established Member Two Rings czum09's Avatar
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    Iowa ftw!
    Aug 10 2014
    B5 s4 stage 3
    United States
    Little progress this weekend
    Aug 10 2014
    B5 s4 stage 3
    United States
    Just doing little things while I wait on gaskets and special tools to arrive
    Aug 10 2014
    B5 s4 stage 3
    United States
    Well just found this.... Can anyone send me in the right direction on what to do.
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    whats wrong?
    Aug 10 2014
    B5 s4 stage 3
    United States
    Quote Originally Posted by y3ti View Post
    whats wrong?
    The Pistons skirt has a notch in it
