Results 1 to 7 of 7
    Apr 15 2014
    Ottawa/Gatineau Canada
    how much fluid do I ned for tranny and rear diff?
    2004 A4 Avant with a MT
    I am going to buy some gear oil from the VW mech down the road as he buys it in bulk.
    How much fluid will I need for a flush of my transmission and my rear diff?
    Thanks all.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Nov 10 2015
    Sudbury, ON
    Rear Diff: http://www.audizine.com/forum/showth...-Rear-Diff-Oil ...... 1.5L of oil
    Trans:
    *Common transmission gear oil capacities, courtesy of JHM so you can order the right amount.
    -B6/B7 S4 w 6-speed manual quattro = 3.5 quarts
    -B5 S4, C5 A6 and Allroad w 6-speed manual quattro = 2.4 quarts
    -B6/B7 A4 w 6-speed manual quattro = 3.7 quarts
    -B6/B7 A4 w 6-speed manual FWD = 3.2 quarts
    -B5/B6 A4 w 5-speed manual quattro = 2.9 quarts
    -B5/B6 A4 w 5-speed manual FWD = 2.7 quarts
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    My 02X transmission has a capacity of 3.5 quarts, and my rear diff took 1.9 (or was it 1.5?) quarts it should be the same unit that you have. Basicly, I filled it till it came out the fill plug. FYI... I did not use the same oil in the rear diff. Personal preference is to use the factory gear lube in the transmission. The rear diff in not very particular about formulation and got Redline GL5 rated 75W-90 lube, no need to use the factory stuff.
    The dealer charged me $29 a quart for the factory stuff I used in the transmission ( G052911A2).
    Is your mechanic factory lube in bulk ( big container) or buying a lot of 1 liter bottles to get a quantity discount or is it an aftermarket equivalent?
    Apr 15 2014
    Quote Originally Posted by Kevin C View Post
    He is a VW/Audi only shop. He gets his oil and gear fluid in big barrels. All is OEM spec and on par for warranty on new cars as per dealer recommendations.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    GL4 for the front diff/tranny and GL5 for the rear diff.
    2019 SQ5 Prestige
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Three pedals or two? Capacities and procedure is different if auto.
    Apr 15 2014
    Quote Originally Posted by MacFady View Post
