Hello Audizine. I purchased a 03 A4 a few weeks ago & been stuck on these forums since. So much knowledge on here! I'm getting ready to change out the upper & lower control arms, inner & outer tie rods, & sway bar links. This site has me excited to get working. I wanted to get the opinions of the forum members before I start this job. To prevent pre-load at the ball joints i'm going to swap the parts while the car is on jack stands, jack up the lower knuckle just until the car starts to rise, and then lock everything down. Is this the best way, or should I measure from the top of the tire to the bottom of the fender before removing the wheel, then put the wheel back on and jack up the lower knuckle until the wheel sits at that measurement, or am I over thinking it? Once the jack is set I'll torque down the upper & lower control arms, sway bar links, and outer tie rod ends @ the ball joint. I will secure the inner tie rods when I install the new ones, and lock the outer tie rod ends in place against the inner rods after installining them the correct number of revolutions. What kind of tool works good for cutting the bands off the boot & are zip ties ok to use to re-secure the boot? Should I use blue Lock Tite on any or all of these fasteners? Just wanted to get everyone's opinions if I'm missing anything. I've been planning and buying parts, now I'm going to start some projects. Thank you to everyone for keeping this forum going, it's a ton of knowledge to new Audi owners like me!
