Results 1 to 6 of 6
    Sep 12 2015
    Hong Kong
    removing fog light question
    I recently installed the RS bumper to my S5 and I was wondering is there a way to remove the fog light without having the car give me a warning signal on the dash? coz now I just kinda hide it by wrapping it around with foil but every time I unlock or turn off my car I have the home coming light feature where it stays on for like 30 seconds before it actually turns off. I can turn that function off but I'd rather keep it on and to do that I'd have to remove the fog light coz I smell it burning the foil.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Have you tried unplugging them to see what happens?
    Sep 12 2015
    Hong Kong
    Quote Originally Posted by JamesRS5 View Post
    the fog light error lights come on on my dash.
    Feb 27 2014
    Dubai
    Ok. What happens if you remove the fuse for the fog lamps and then disconnect them?
    If that's still throwing a fault; are you able to measure the resistance of the fog light bulb?
    If you can check this, it's just a case of getting a couple of resistors to the same value of the bulbs and plugging them into the connectors where you have just removed the fog lamps.
    Sep 12 2015
    Hong Kong
    thanks!! let me try that
    Aug 04 2010
    Queenz/Westchester
    Vag com should have a option for fog lights that you can unselect
    Sent from my Galaxy S6+ using Tapatalk
