2001 Audi Allroad Quattro, Fully Loaded - $14900
Immaculate car! Meticulously maintained. Only 123,000 miles. It has a RARE 6 speed. Have all maintenance records, manuals, shop manuals, etc.
Leather, Bose stereo, solar sunroof, had new computer put in, motor mounts, filters/ fluids changed every 2500 mi, Mobil 1, 2.7l, bi-turbo, 250hp stock, chip it & get 90 more - same engine as the Avant.
Trim Levels, Options
Available Trim Levels: Allroad 2.7T Quattro
Options:
Premium Package: Memory for both front seat positions and electrically folding exterior mirrors; Xenon high intensity discharge headlights; Automatic dimming interior and exterior mirrors
Convenience Package: Heated front and rear seats; HomeLink 3 channel remote transmitter located in driver's sunvisor; Heated multi-function steering wheel
Warm Weather Package: Solar sunroof; Rear side window sun shades
Guidance Package: GPS Navigation system; Parktronic (NOT INSTALLED, TOO SMALL SCREEN)
Bose 200 watt premium sound system with sunroof
Motorola hands free cellular telephone
Rear set mounted side airbags
17 inch 5-spoke alloy wheel/ twin spoke dimensional effect (JUST REFURBISHED 4/2016)
6-disc CD changer
Power sunroof W/ SOLAR PANEL
Exterior Color: SILVER / BLACK TRIM
Technical Specs
Engine/Engine Design
Model: Allroad 2.7T Quattro
Type: Six-cylinder four-stroke, spark ignition, two light alloy cylinder heads, three inlets and two (sodium-cooled) exhaust valves, DOHC, twin turbochargers
Bore: 3.19 in.
Stroke: 3.40 in.
Displacement: 163 cu. in.
Compression Ratio: 9.3:1
Horsepower (SAE Net): 250 @ 5800 RPM -- CHIP WILL BRING TO AVANT SPECS
Torque: 258 ft. lbs.@ 3400 RPM -- CHIP WILL BRING TO AVANT SPECS
Cylinder block: Cast iron
Crankshaft: Forged Steel, 4 main bearings
Cylinder head: Aluminum alloy
Valve Train: DOHC, belt driven, hydraulic lifters / variable intake valve timing and variable geometry composite intake manifold
Firing Order: 1-4-3-6-2-5
Cooling System: Water-cooled, thermostatically controlled radiator fan
Fuel/Ignition System: Electronic sequential fuel injection, mapped-characteristic ignition with solid-state direct ignition, variable intake camshaft control, cylinder-selective knock control, exhaust temperature control, coordinated engine-torque control, ME 7.0 Motronic with electronic throttle control
Emission System: Two tubular exhaust manifolds with air-gap insulation, two pre-converters close to engine, two 3-way catalytic converters, two heated oxygen sensors
Drivetrain
Type: Quattro all-wheel drive
Transmission: 6-speed manual with syncro reverse or Electronically controlled five-speed automatic with Tiptronic, dynamic shift program (DSP) and hill detection capability, lock-up torque converter and automatic shift lock
Gear Ratios:
1st
2nd
3rd
4th
5th
6th
Reverse
Final Drive
Manual (automatic)
3.750:1 (3.665:1)
2.059:1 (1.999:1)
1.417:1 (1.407:1)
1.071:1 (1.000:1)
0.857:1 (0.742:1)
0.730:1 (------)
3.455:1 (4.096:1)
4.375:1 (3.091:1)
Steering
Type: Maintenance-free rack & pinion, servotronic - vehicle speed variable power assist
Ratio: 16.2:1
Turns (lock-to-lock): 2.81
Turning circle (curb-to-curb): 38.3 ft. (11.7 m)
Suspension
Front: Four-link independent wheel suspension, tubular anti-roll bar, air suspension spring strut with twin-tub gas shock absorbers
Rear: Double wishbones, sub-frame, anti-roll bar, load-controlled damping via air suspension spring strut
Brakes
Service brake: Dual-circuit brakes system with diagonal split, ABS/EBD, brake servo. At front, ventilated discs and high performance 4 pad HP2 brakes. At rear ventilated disc brakes.
Front, size and type: 12.6 in. (321 mm) - Ventilated disc
Rear, size and type: 10.1 in. (256 mm) - Ventilated disc
Wheels & Tires: (JUST REFURBISHED 4/2016)
Wheel size: 7.5 x 17 5-spoke allroad design 225/55 97 H
Tire size: 225/55 HR 17, High Performance Tire
Body
Material: Unitary, fully galvanized steel, aluminum front hood
Corrosion protection: Multi-step anti-corrosion process
Capacities
Engine Oil: 6.3 U.S. quarts
Fuel Tank: 18.5 U.S. gallo
List Date: 4/15/2016
For more info, click here to view the original listing: 2001 Audi Allroad Quattro, Fully Loaded - $14900
This item is no longer available.
