Well I took the plunge I purchased the CXracing ko4 and did the rebuild with the larger better Journal bearing.
I also purchased the XSpower exhaust tubular mainfold.
I will begin on this more than likely this weekend I will try to keep this post updated as I go.
Build quilty is ok....
Turbo has definitely been balanced you can see the grind marks on the compressor side however I'm not sure how well it was balanced.
I do have a few questions if anyone can help.
1. I'll be replacing the coolant, oil feed and oil return lines with braided lines. On the oil feed and coolant lines do I need Crush washers between the turbo and the connector.
2. I plan on using -4an for oil feed. -6 for coolant lines and -8an for oil return, are these lines sufficient?
3. I'm also not using a oil restrictor which I don't believe you need on a journal bearing turbo correct?
