Results 1 to 14 of 14
    Feb 22 2016
    montreal
    3.2L Quattro start up issue
    Hey guys, I'm having this issue where sometimes when I start my car it starts perfectly fine, but some other times, it doesn't turn on at all, the rpm is so low that it just dies, and right after that i start again, it makes a sounds like if its choking or stalling, and the only way of getting passed that sound is when is when i push on the gas...
    Is it my alternator? water pump? battery? starter? any other issues?
    Please help guys!
    I'm literally going nuts
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    Is it random or do you notice certain behaviors at certain engine temps? (i.e. Cold/warm)
    Do you have vagcom?
    Could be time for a carbon clean.
    2013 Phantom Black C7 S6 Stage 3 | 2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    IG: tyscalzone
    Senior Member Two Rings mitchell.'s Avatar
    Oct 27 2014
    Toronto, Ontario
    Quote Originally Posted by rostami View Post
    Please help guys!
    Any CELs?
    Drive On, Brother!
    Feb 22 2016
    montreal
    Quote Originally Posted by Quattro 4 Life View Post
    Do you have vagcom?
    Well the first time i start the car for the day, it starts okay.. But then i drive it around and do my stuff, after leaving it parked for an hour or 2, thats when it dies on me stalls on start, even sometimes when i turn it on, i feel like something is rubbing on the fan or makes a sound thats sounds like that..
    No i dont have vagcom but i do have a codereader.. And nothing comes up
    What should i clean up? I added a fuel injector cleaner, i changed my filters, except my fuel filter which is located near the exhaust i think.
    Feb 22 2016
    montreal
    Quote Originally Posted by mitchell. View Post
    Any CELs?
    Nop, no check engine lights, thats why im getting frustrated cause i have no clue what it can be
    Feb 05 2008
    Kenmore
    Yeah fuel filter isn't likely a cause but could be useful to change. Harsh cold start-ups can be partially caused by carbon buildup.
    How many miles?
    IG: tyscalzone
    Feb 22 2016
    montreal
    How many miles?
    How much does a carbon clean up cost usually? (Noob question i know)
    2008 with 137xxx miles mostly highway from what my previous owner said.
    But how can you be sure its not the alternator or anything else?
    Feb 05 2008
    Kenmore
    Yeah carbon clean is just a general thing to consider, I wouldn't jump right in on getting that done. Not cheap from what I've seen.
    You inspected the spark plugs?
    IG: tyscalzone
    Feb 22 2016
    montreal
    Not yet haven't checked that, can it happen that one of them don't work and the rest works? Or the car just doesnt turn on if one is burnt
    Feb 05 2008
    Kenmore
    Just pull all of them and look for irregularities. Post a pic when you get them out.
    IG: tyscalzone
    Feb 22 2016
    montreal
    will do! thanks man, ill get back with you shortly! actually what spark plug is best for it? NGK or BOSCH?
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    I think it depends on the year, some 2007s used Bosch. Mine's a 2006, ran like crap with Bosch and everything else except for the NGKs that are OEM for the 3.2
    Feb 22 2016
    montreal
    Quote Originally Posted by b7_Andy View Post
    Im 2008 soo i guess its NGK is the good ones?
    Jul 18 2015
    https://www.ecstuning.com/Audi-B7_A4...ugs/ES2996717/
    These are considered the "genuine" ones for our 3.2s. I use the same ones and my car runs great.
