So i got bored tonight and decided to carefully open open my fuel filter and get some better damn photos than whats floating around the internet.
So here it is, a 4port filter with labels:
So yea we all get that fuel goes in, gets filtered and gets regulated to 4bar/58psi. The question for me was how does it flow, internally and what all the ports allow.
Without further adooooo....
Here you see the top carefully opened with angle grinder, hammer and screwdriver
Now here is a look down the filter, Fuel enters the VL port where it then surrounds and goes through the filter pleats entering the center of the filter chamber and THEN flowing into pressure chamber the via the 3 long slits surrounding the center return (RL) tunnel.
Popping the FPR out reveals an oring sealing it off from the rest of the filter and that the "EJ" port is merely a vent for when the diaphragm of the FPR is pushed up by incoming fuel pressure.
Now what happens here is that filter fuel pressurizes the upper pressure chamber, fuel line, and fuel rail. Once 4bar pressure is reached the FPR lifts and fuel flows through the 4 slots in the bottom of it and OUT THE CENTER into the plastic straw. From there it exits the filter via "RL" and goes to the top of the fuel tank on the driver side transfer pump fuel hat.
Now that's that. Time for beer and dinner.
P.S. I discovered that the regulator is capable of holding vacuum so that makes me wonder IF we applied vacuum/boost to the EJ port instead of sending it back to the tank would the FPR act as a rising rate?
hmmm...
