Originally Posted by
C5S6
California would not know if you left everything in place. As I understand the system, the SAI only runs for a few seconds when the coolant is cold. Your car would already be at or near operating temp when they test, so it won't run anyway even if it was working. As long as the readiness is set you'd pass.
Recently in my S6, the SAI pump just started making a bunch of noise and within days threw a CEL for insufficient flow. I had it coded out and pulled the 40A maxifuse for the pump motor so it wouldn't kill itself. The coding is basically setting the expected threshold of airflow to 0.
Hmm...You still have that file w/ the SAI coded out?
I have two V8's that could use it. Actually, SAI works perfect on both, so I'd leave it until it gave me a reason to trash it. But I'd still love to not have to worry about the junk turning the yellow light on.
FWIW I'm pretty sure you can use nearly any VW Passat, Jetta, Golf, blah blah..Audi B5 /B6 etc.. SAIP and it'll plug in and work. There were a couple models that had obviously different pumps (like the B5 S4)..but even that would probably work.
Anyway. I want that file.
