Page 44 of 115 FirstFirst ... 3442434445465494 ... LastLast
Results 1,721 to 1,760 of 4571
  1. #1721
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Quote Originally Posted by Fastbke170 View Post
    Nah not you dude, your dyno is the quarter mile. You have the same setup I do more or less. The others were quick to try and dim my spirits toting k03 shit. No worries. Just showing the irony.
    Sent from my SM-G950U using Tapatalk
    Okay cool, just didn't want you to take what I said the wrong way. I agree that weather plays a huge role in power output.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
  2. #1722
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    Quote Originally Posted by B1GW3AV3R View Post
    Having this is my trunk adds +50hp, finally getting it installed on Wednesday HPA K04 paired with APR K04 tune. Let's see how it goes.
    Sent from my Pixel using Audizine mobile app
    Finally been waiting to hear about this and what was the shop you were using for the cheap install? Might have the jhm gb in my future if I can't find seats.
  3. #1723
    Established Member Two Rings B1GW3AV3R's Avatar
    May 04 2017
    2002 Honda s2000 2001 Audi s4
    PA
    Quote Originally Posted by ECDT View Post
    I would talk to Darryl over at HPA, I got a better deal on this then even the lowest price on the JHM turbo, I don't want to disclose actual prices but he hooked me up. Also the shop quoted me a little more then I was expecting just because this will be the first HPA turbo he's done on a b8, but if it goes as easy as the APR k04's he's done he will discount the price back down, I'll let you know.
  4. #1724
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    The HPA is nowhere near as easy to install as the APR.
  5. #1725
    May 04 2017
    PA
    Quote Originally Posted by pierreb View Post
    They have a new kit now, the old one was different the new one can be mounted up with any HFC, and is direct fitment. They just changed it last month.
  6. #1726
    2020 A4 allroad
    NH
    Ah that's good to hear. Good luck with yours, you will definitely enjoy it once done. :)
  7. #1727
    May 04 2017
    PA
    Thanks man! But then again you never know, I'm hoping it goes as easy as they say. Ill be finding out Wednesday when I get the bill lol
  8. #1728
    Aug 17 2015
    California
    Finally I get to join this club!
    My shop finished up the JHM turbo install this morning. It was pretty straight forward, except some mixup with switching the coolant port plug over to the other port. They stripped the plug when trying to remove it and we had to wait for another plug.
    I just got home from getting the APR tune and only had a chance to drive about 20 miles in 92 degree heat.
    Car pulls hard all the way to redline, and sounds a lot meaner. Love the turbo spool sound, much better than K03.
    It was 92 degrees outside and I still have PFR7 plugs @ 0.032 gap. I think that needs to change ASAP for a smoother 4000 rpm and up. I can feel a couple hiccups and timing pull at high RPM, same thing I felt when I ran colder plugs on the K03. I do not attribute this to the tune/turbo at all. But give me a few more days to really get used to it.
    So far, loving it....
  9. #1729
    May 04 2017
    PA
    Quote Originally Posted by A4x View Post
    My shop finished up the JHM turbo install this morning. It was pretty easy, except some mixup with switching the coolant port and plugging the other one. They stripped the plug when trying to remove it.
    What plugs are you going to use? My place is recommending NGK BKR8EIX gapped to .024.
  10. #1730
    Aug 17 2015
    California
    Yea that is what is on the APR website as their recommendation. I will probably run those but at 0.026 or 0.028 with the R8 coils.
  11. #1731
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    I asked Daryl the same question and he told me they designed their K04 for stock plugs.
    I am currently running NGK7 (holdover from my stage 2 setup) but I have a set of 8's that APR recommends for their K04 kit.
    So basically just adding some additional confusion to the thread in hopes someone has a better answer.
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
  12. #1732
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    UGhh.. that is awesome!! Congrats man.
    Posts like this makes me even more anxious lol!
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
  13. #1733
    May 04 2017
    PA
    Quote Originally Posted by IHave2Turbos View Post
    I'll keep my other plugs just in case, I'm switching to the 8's and r8 coils.
  14. #1734
    Aug 17 2015
    Keep us posted on your results. I should also add that I have the new revision of the turbo kit as well.
  15. #1735
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    When I had my car tuned they switched out my Bkr8eix to the stock heat range plug. Now my car was experiencing a lot misfires during the tune, most likely due to my car needing a carbon clean. The tuner at Force Fed added for a street car without major engine work the stock heat range works fine. I think they put in bkr6e gapped at .022 to deal with the misfires. I have about 3k on plugs now and about to excise said carbon this weekend. I will probably order a set the same the tuner installed as well as a stock 7 heat range platinum.
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
  16. #1736
    2020 A4 allroad
    NH
    One would think the tune has more to do with the plugs than the design of the k04 kit. Perhaps I'm wrong.
  17. #1737
    May 04 2017
    PA
    That's what I was thinking, since I'm going with APR's tune I figured I should go with what they recommend.
  18. #1738
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    The shop i got mine installed at had zero issues (except with putting the turbo blanket on). Took about a day including carbon cleaning and swapping the IM.
    Hes a great guy to deal with!
    Side note its great to see all the K04'ers!
    Sent from my SM-G925W8 using Tapatalk
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
  19. #1739
    2020 A4 allroad
    NH
    That's what I would recommend but LOG the car for ignition probs regardless !
  20. #1740
    2020 A4 allroad
    NH
    Quote Originally Posted by Marko S View Post
    The shop i got mine installed at had zero issues (except with putting the turbo blanket on). Took about a day including carbon cleaning and swapping the IM. Hes a great guy to deal with!
    Basing that on old kit, I guess a new one is out. Is that what you got too?
  21. #1741
    Mar 03 2015
    I have the old one paired to their hfc. The only diff on the new one os that its not specific to their hfc.
  22. #1742
    Veteran Member Four Rings AUDacIouS4's Avatar
    Mar 11 2016
    981 Cayman GTS/ 2018 Ford F150 FX4 2.7
    Orange County CA
    Let's see some MAF g/s for this JHM hybrid k04??
  23. #1743
    2020 A4 allroad
    NH
    Most folks with those kits will have trouble with the IC piping connection from what I recall. And the coolant line angles. Some shops can fabricate solutions easily.
  24. #1744
    Mar 03 2015
    I have the ecode silicone hoses and they never brought up any issues. But i agree it probably depends on the shop you take it to.
  25. #1745
    Mar 11 2016
    Orange County CA
    For Those running a CTS BW k04, Do you need to buy their test pipe/HFC or will any HFC, Like 034, work?
    CTS told me I have to buy theirs, which I don't believe.
  26. #1746
    Aug 17 2015
    i believe it is because they use a true k04 and the outlet flange is different. old hpa kit had the same requirement for the same reason i believe
    C7.5 S6
    B8 A4
  27. #1747
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Significant price difference over the JHM?
  28. #1748
    Aug 17 2015
    no but based on some of the data it would seem the cts k04 makes the most power being a bigger turbo compared to the hybrids.
    C7.5 S6
    B8 A4
  29. #1749
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    It's not... at least compared to ours (which isn't a hybrid either).
  30. #1750
    Aug 17 2015
    didn't mean to imply your turbo was a hybrid or not was just commenting on price difference question.
    C7.5 S6
    B8 A4
  31. #1751
    May 04 2017
    PA
    Quote Originally Posted by Jake@JHM View Post
    What do you call yours? Just your own custom turbo?
  32. #1752
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    @Jake@JHM can you define 'hybrid turbo'?
    i find this term to be often used/abused
  33. #1753
    May 04 2017
    PA
    Quote Originally Posted by johnnySV View Post
    I would like to know this as well. The main reason I went with HPA was 1. Cost, 2. They didn't oversell me, they told the truth about their product (it's a hybrid) and didn't bash any other company. Even if JHM doesn't consider their turbo a hybrid it's still not a true BW K04 so at that point I think you just call it their own manufactured turbo.
  34. #1754
    Dec 30 2012
    210/TX
    I did my own install with the DIY write up in here. No pictures just reading it. I'm no mechanic but I did it. Also have the APR tune done at Brink Motorsports in Austin, TX. You will enjoy the extra power. I don't have dyno numbers but a big difference. I still have a stock IC but will upgrade soon.
  35. #1755
    Dec 30 2012
    210/TX
    I'm running stock plugs and coils. I want to get the red tops and NGK to see if a difference
  36. #1756
    Dec 30 2012
    210/TX
    No need to fab anything
  37. #1757
    Dec 30 2012
    210/TX
    I'll be happy to answer any questions on the install of the HPA kit.
  38. #1758
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    I think the term hybrid would generally mean something along the lines of taking a k03 and modifying it to take a K04 compressor wheel thus making a hybrid k04. Vs being a true K04 and modifying it. So jhms would not be a hybrid but rather an enhanced k04.
  39. #1759
    May 04 2017
    PA
    Quote Originally Posted by onedumslack View Post
    So APRs kit would be a hybrid. I think the only true BW K04 is the cts kit. JHM may have a K04 but it's their own made it's not a BW. So how do you know it functions as such. I think they all will do their job.
  40. #1760
    Mar 05 2014
    phoenix/az/usa
    I see. I overlooked that. I had thought I saw jhm's started as a BW K04 but now that I look at their site it just references K04.
