Page 34 of 115 FirstFirst ... 2432333435364484 ... LastLast
Results 1,321 to 1,360 of 4571
  1. #1321
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    Things are about to get interesting in the next few months I presume...
    Oz
    2013 Scuba Blue A4 Premium
    EuroCode / APR / H&R / Bilstein / VagCom / AWE / NGK / 034 / GFB / HRE / Valentine1 HW / CR15 / Black Viton Injector Seals / Fluidamper / Ko4 #00Negative
  2. #1322
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^Interesting is an understatement! Gloves are coming off the Avant, and she will be ready for another great track day in May.
  3. #1323
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    Quote Originally Posted by hyperunion View Post
    Really like the look of this!.. should work right up with Apr's new dp as well.. unlike cts's
    Sent from my Nexus 7 using Tapatalk
    hehe
  4. #1324
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Planning this out, how is everyone adapting IC hose sizes? Trying to get my shopping list in order....the JHM kit says it drops in like the factory turbo, meaning it likely uses factory IC hose size, which is what, 2.25", 1.75"? I'm planning on installing the ECS IC pipe kit at the same time which is 2.5", are there issues with using an silicon adapter up to that size? The ECS kit comes with a turbo muffler delete to adapt it up to 2.5" which looks like it controls turbulence better than just sticking on a dumb off the shelf fitting.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
  5. #1325
    Jun 05 2009
    Scottsdale Arizona
    ^I'm going to keep my factory hoses, though I am running the APR FMIC. I assume those hose (Stock) are 2.25"?
    JHM is telling me to get with the program so I don't miss this next batch of production K04-R's
  6. #1326
    Sep 17 2006
    ^^^ya I'll be going with the APR FMIC too, installing all at the same time. Guess I can figure out all the proper fittings on the bench before I make my car undriveable and need to make a run to Autozone.
    past: B6 S4, B5 A4
  7. #1327
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    Quote Originally Posted by earhythmic View Post
    Man, all this talk of hoping on the JHM train has me chomping at the bit! Earhythmic, you know I'm gonna be banging on my 6s when you're about to do your install!
    This thread is heating up like Kim Jong's uranium enrichment program!
  8. #1328
    Aug 17 2015
    California
    Quote Originally Posted by Poodini View Post
    I'm also in the same boat as you! However I should save the money as a downpayment on my next car!
    Can someone please explain to me what all the hype is about the JHM kit? Yea it looks nice. I suspect the hype is because the kit come in $1200 less than APR (however no software included), and suspected quality is better than Frankenturbo (although not proven except based on JHMs reputation??)?
  9. #1329
    Jun 05 2009
    Scottsdale Arizona
    ^ Well for me, its about the modifications to the wheel, ceramic heat coating, and other details like it being a direct fit.
    Price is overwhelmingly the main reason, but again, not having to buy another HFC, when I just replaced mine after it cracked is a big plus. Also, I don't think APR sells their K04 with the tune included?
    Regarding mods to the turbine wheel, I have seen the same techniques used on the Borg-Warner VNT-15 for the VW ALH TDI Engines. Kerma TDI offered which as I recall was a VNT-17/22 Hybrid?
    Anyway, I found those points of their product interesting and potentially will make the build a bit more interesting and hopefully this project will lift up B8 modding a bit. Really, this platform could use some help in the power modification dept.
  10. #1330
    Aug 17 2015
    California
    ^^ So with the added features of this turbo, do you see a benefit of going Eurodone or some custome software as opposed to APR software, in order to maximize the potential of the turbo?
    Also, I thought APRs $3000 kit included their software.
  11. #1331
    May 24 2013
    APR Ko4 $2999 (for Existing APR Tuned customers) comes with Turbo & Tune. If you wait for sales it can be had for $2699.
    If I were adventurous and live relatively close to a custom tuner then maybe I would get a custom tune, but the fact that APR has a pretty good tune and can be accessed from most shops is what would draw me more towards APR.
    Oz
  12. #1332
    Jun 05 2009
    Scottsdale Arizona
    Good question. I was going to see what the cost of United Motorsports tune and a bit of dyno time would run, like Slowone has done.
    But its my DD and riding the Ducati to work doesn't work well everyday. Also, from what I have read, the tune from APR is adequate. Got to ask Bluewater what they think.
  13. #1333
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by OzeyeruZ View Post
    Oz
    This is the route I took and got it for that $2699. Just finished the install and got my tune loaded yesterday... I wish I did this years ago, I love it! Anyone want to come help me install the W/M kit?
  14. #1334
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Quote Originally Posted by A4x View Post
    APR does include the software in their kit.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
  15. #1335
    May 24 2013
    Quote Originally Posted by The Infiltrator View Post
    WM Kit will definitely help with the Florida heat! Are you doing dual nozzle?
    Oz
  16. #1336
    Sep 09 2010
    Destin, FL
    Oz
    Single
    Lots of reading to do.
    http://www.audizine.com/forum/showth...e-running-meth
    http://www.audizine.com/forum/showth...at-do-you-have
    http://www.golfmk6.com/forums/showthread.php?t=31857
  17. #1337
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Quote Originally Posted by A4 Centaur View Post
    If I read this post without the context of the discussion it's in, I would have thought you were talking about the frankenturbo. In fact I'd even bet that eurodyne's F23L tune would match up with and work better on this K04-R than a K04 file.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
  18. #1338
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Quote Originally Posted by lettuce View Post
    The wastegate setting on this turbo I bet will be lower than that of which on Frankenturbo. My guess is this due to the fact that JHM said it works great with APR software. All the logs that I've seen Frankenturbo on APR software the duty cycle is dropped to meet boost and avoid over shooting. If this is the case and JHM preload is set lower than that of Frankenturbo, I don't see it working to well with Eurodyne unless the PID maps are changed to accommodate the wastegate. And even then it still might not hit requested due to the wastegate door being blown open.
    But i agree Eurodyne would be better for the Long haul and will achieve more power. For those looking to run this turbo with APR software I have a feeling that the results you'll get are going to be the same as there own K04 kit and no gains over.
    I also will say that those saying Frankenturbo having poor quality, you are severely wrong. They even offer a two year warranty on the product. And you can get it ceramic coated as well. The quality is top notch and his customer service is by far better than any large competitor. A very stand up company. I was on the fence for years on Frankenturbo and I can say that all my worries with them have since changed.
  19. #1339
    Jun 19 2015
    Boston
    Quote Originally Posted by Alex1188 View Post
    All good points. And you can change wastegate preload with just springs, no?
    And I've probably driven my car harder than most, with over 100 timeslips from the dragstrip in the 2 years I've been running the frankenturbo. It runs just as good as the day I installed it, and the owner of the company answers all my emails within 24 hours, even personally helping me pour over logs.
  20. #1340
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
  21. #1341
    May 24 2013
    Quote Originally Posted by Jake@JHM View Post
    The price looks right!
    Oz
  22. #1342
    Mar 10 2013
    The wastegate preload could be adjusted by just tightening the actuator or installing a different one if the actuator isn't adjustable.
    I am curious to see how this turbo pans out. But I still think the best turbo combo out there right now is frankenturbo/eurodyne.
    - - - Updated - - -
    What size is the compressor wheel on this Ko4-R turbo?
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
  23. #1343
    Oct 26 2015
    Fremont, NorCal
    BOOM! I had been hedging on whether to take the K04 plunge or not for the longest. Going from stock, then APR Stage 1 within 3 months of purchasing it fresh off the delivery truck back in Dec. '09, then to Stage 2, the gains have been metered out well and has been a reliable DD now for 7+ years! The only caveat being that I've had to replace the stock turbo 3 TIMES, all for the same P2099 Low/no boost due to wastegate failure B.S! Two were covered under warranty. The third, I was already at near 100k, well outside their 70k extension for this very issue. Pleaded my case with my local dealership which was escalated to Audi North America, advocated hard for myself and managed to get them to agree on a Goodwill repair. Essentially, AoNA provided the replacement turbo, free of charge but I was on the hook for the install. Roughly 60/40 split which sure as hell was better than paying full boat!
    Only regret was not going K04 then but, better late than never I suppose. Can't wait for Earrhythmic and others who go with the JHM turbo how it plays out before pulling the trigger.
  24. #1344
    Aug 31 2011
    Lathrop
    On the B7 A4, we compared two cars with same hardware and tuning. One with an OEM S3 and the other with our K04-R. The K04-R hit much harder and pulled away on the top end.
    Waste gate cracking pressure is set like an OEM S3, however waste gates are simple adjustments if you wanted to change it.
  25. #1345
    Veteran Member Three Rings VNA4's Avatar
    Jun 20 2015
    San Jose
    @poodini I'd sale you my k04 when CTS releases their kit
    S4 B8.5 2014
    KW H.A.S. / EuroCode ÜSS Adjustable Sway Bar / AWE Touring Diamond Black / 034 Stage 2+ / DP 187mm / APR Stage II Carbon Back Pipe
    20 x 10 et35 StanceWheels SF01 [PowderCoated Diamond Black]
    SOLD
    AUDI A4 B8 Premium Plus Sport:
    CTS k04/ APR k04 File / AWE Quad exhaust / FMIC: TR8
    VIP VRC 13 : 19X9.5 / Tires: 255/35/19 / Solo werks Coilovers / OE S4 Front Brake Upgrade Kit
  26. #1346
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    When you say 'hit much harder'
    Do you mean the turbo spoiled quicker? Or just boost pressure was higher?
    Also, what tuners are you guys going to be pairing this with anyway? I assume, as others noted, if we used APR software it would just provide regular K04 numbers.
    I guess I'm asking if any tuners are going to calibrate specifically for the K04-R (or which you are planning to use)
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
  27. #1347
    Jan 03 2012
    Wilmington NC
    Because what I really want to know is.... E85 plus K04-R... I'll be the fastest?
    2019 S4 Build
    IG: @steves_s4
  28. #1348
    Aug 31 2011
    Lathrop
    Hit harder = boost comes in much quicker
    We won't be pairing with anyone, but any competent Tuners OTS K04 software should work. Eventually we will have our own software for it for the B8.
  29. #1349
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    We need something slightly larger than k04 and smaller than APRs EFR attempt. Something 400-425hp at the crank on 93 octane
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  30. #1350
    Sep 17 2006
    past: B6 S4, B5 A4
  31. #1351
    Aug 31 2011
    Lathrop
    Lol for the most part it would bolt up
  32. #1352
    Jan 15 2014
    Boston, MA
    Wait what? That?
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  33. #1353
    Aug 31 2011
    Lathrop
    Quote Originally Posted by AllroadCorbin View Post
    Wait what? That?
    Yea because it was designed to be a drop in replacement for a k03 maintaining OEM B7 locations as if it were a K03. The only thing that may not work right is the compressor housing to intercooler connection as it was designed for our B7 FMIC.
  34. #1354
    Jan 15 2014
    Boston, MA
    But sadly this would need a custom map from United or something since you guys don't offer any B8 software yet. Interesting to know though!
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  35. #1355
    Aug 31 2011
    Lathrop
    Yeah you would be on your own for software
  36. #1356
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    Malone can tune anything.
    Sent from my SM-G925W8 using Tapatalk
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
  37. #1357
    Jan 15 2014
    Boston, MA
    Quote Originally Posted by Marko S View Post
    They're the diesel guys
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  38. #1358
    Mar 03 2015
    Theyve tuned a 600+hp b7 a4 here in ontario. I was debating between malone and hpa for my hpa k04/mani. Still not sure.
  39. #1359
    Mar 10 2013
    Eurodyne has a stage 3 map as well...
  40. #1360
    Veteran Member Four Rings AUDacIouS4's Avatar
    Mar 11 2016
    981 Cayman GTS/ 2018 Ford F150 FX4 2.7
    Orange County CA
    Its really an easy install. I did mine a few months ago in a little over an hour. All factory hoses fit just fine, no need for aftermarket hoses. I would suggest disconnecting the airbox(Heimholtz resonator) located on the driver side on the plastic charge pipe. Cap it off with a 1" chair leg cover and a hose clamp.
    a slave of corruption no longer
