The last two times it happened my egts were 1800+ for at least half a mile and my engine went kaboom. I was an idiot thinking I had fixed the issue and just went for it. When it happened this time I was aware my egts were high(1650 at the most) via the gauge I installed. I've been letting off after about 5 sceonds at. Been doing so for about 4 months, but within the last couple weeks the attached picture happened.
I installed a 300psi meth pump with a 10gph nozzle after the first the destruction of the first two times. I noticed 0 change in egt's with -20 windshield washer fluid. It was still going up to 1650+ after a good pull and would continue to climb unless I let off.
My timing pull is 7 degrees at the most. Up top my timing at 6k rpm 5.5 load I have about 16 degrees which... I suppose that may be a lot?, but it's all about that pull, which I don't really have.
The previous times all the porcelain broke off.. Not just the tip of it. Today I put half a gallon of denatured alcohol in with 2 gallons of -20 and my egts didn't go over 1550. Even after running out 5th gear. Super stoked about that! If I increased my octane that takes me back to being curious if it's detonating? Nothing I log points to it doing so. Any ideas about what the cause may be (high egt's or just detonating?)
