I have some crappy pictures of it finished and an even crappier drawing. Sorry, it didn't occur to me to post this until after I was done.
The constant tension spring breaks free from the thin plastic slot it resides in and rolls up like an old window shade from looney tunes. I simply removed the flat clear plastic bit that sent light to the front of the cup holder and bent the end of the spring down at a 90 degree angle. I then hooked the end of the spring under the fatter plastic beneath where it would normally go. It looks just like a tape-measure.
So you lose the light, but you gain a cup holder.
Here you can see the thin broken slot where the end of the spring used to reside. Notice how the end of the spring is now tilted down at a 90 degree angle and hooked onto the end like a tape-measure.
