Hello everyone, I'm new to Audis and have been tinkering with the idea of buying a B5 S4. I found this 2001 S4 that has been swapped from Tip to an 01E but has a couple little things that still need to be done. There's some cosmetic stuff that doesn't bother me too much, I'm rather focused on making sure the car will be mechanically sound. The ad lists that the clutch vent valve needs to be wired and the ecu needs to be coded for manual. If I wired the clutch vent valve and had a shop recode the ecu for manual with a vcds, would the swap be finished or are there other things that may require me to put in money? Also, is the list of new parts installed on the car missing anything that should have been replaced due to wear and tear and/or the added stress from stage 3? Thank you, I appreciate any help.
