Results 1 to 17 of 17
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Thoughts on FT vs. GTRS
    Was going to bump this thread, but not with all the bickering going on there- http://www.audizine.com/forum/showth...kenturbo-GTRS/
    Basically, I am tired of 150hp in my DD avant. Passing sucks, pulling out from a light sucks, merging sucks, basically anything besides going slow sucks. I need more power.
    I commute a bunch, 150 miles a day at least, so reliability is paramount here- no stupid stuff like under manifold coolant pipes and shit like that on my sedan. I just want a better, faster version of the car that came from the factory. But just as reliable (which doesn't say much lol).
    I want your thoughts on if a GTRS is worth the extra dough over a FT for a few HP. And keep in mind, the most HP is not the goal here. I just want something with extra umph and RELIABLE. I do not want to be left on the side of the road. This is going to be a very basic build when and if I pull the trigger. No FMIC, no 3" exhaust, just enough stuff to get by.
    I will probably swap to AWM ecu.
    As it sits, the avant had 237k miles on it. The head only has 30k. So, I will probably rebuild a lower end for it just because. The engine is healthy the way it is as far as I am concerned, but a fresh lower end wouldn't hurt. If I rebuild a lower end, I will put rods in it just because.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    If BW EFR is not out the question, you can choose a good sized one, internal or external wastegate, whatever you wish.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by a4kamila6 View Post
    EFR is out of the question. If I was going to do that, it would go in my sedan. Bascially, I am looking at keeping the stock flange but something less than a 2871 since that is what my sedan has.
    2000 S4- Working?
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    I put my car back to stockish for emissions and holy s#$% is it boring. i had an eliminator and it was fun on stock exhaust, stock intercooler.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Active Member Three Rings 10kredline's Avatar
    Feb 03 2007
    San Gangster Valley, CA
    I was running my FT on stock intercooler and a stage 1 tune at the beginning and it was pretty quick and enough for DD, easily passing up people. Ran that setup for about a year and it was fine. Is the gtrs new? Big price difference? FT flows similar to the gtrs anyways. If I were you, I'd save the money and put that towards your sedan, since the avant is your long commute DD.
    Current - 2011 Audi S4 B8 : IE Stage 2 Single : IE DSG Tune : IE Intake : CTS 180mm : 034 Engine/Trans/Insert : ECS X-Pipe : H&R Sport Springs : Michelin PS A/S 4
    SOLD - 1999 Audi A4 Santorin Blue : AEB 1.8TQM: F21 Turbo : UM Stage 3 : 3" MAF : Siemen 630cc : CX Racing FMIC : SSAC Test Pipe + RAI J-Pipe O2 spacer+ SSAC Full Exhaust : U-Shape Intake+AEM Dryflow : 034 2.0T Coil Conversion : Southbend Stage 2 : ST Coilovers : Walbro 255 Fuel pump : APR Snub
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I have the "stage 2" kompresd tune and it is more then enough for a DD car. Passing is easy, no down shifting needed. Merging is easy, again, no downshifting. Lights aren't a hassle anymore as well. I know your thinking an FT or GTRS but I think a simple tune will suffice since your not worried about HP or things like that. If the turbo on the avant is bad, go FT I think. Cheaper, proven.
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Getting it chipped should be the first step. If that doesn't suffice, would recommend upgrading your K03 for BW K04-015. Not sure which B5 you have, but if AEB, GIAC PC16 setup or even the base 5Bar K04 file should be adequate for the DD purpose. That's what I have on my B5 (mods on sig) and (knock on wood) has been reliable since I upgraded 7yrs/60k miles ago. It's been relegated to beater status now that I have the S4, but it's plenty fast stop light to stop light.
    As far as FT, haven't read any recent slappy dunbar threads but I recall F4H-L (early version) and F21's have been pretty good, but population of owners chiming in on reliability not as established as Borg Warner (based on inference and anecdotal evidence).
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Established Member Two Rings SacSantorin's Avatar
    Aug 18 2015
    Almost Canada, WA
    I just installed a F21 on my b5 about a month ago. I love it! I'm still working on revisions for my tune with Motoza, but I love the low end torque it has. I don't really have much experience with the GTRS, but the F21 definitely makes the car quick. You won't be punking on any stangs but it makes for a great DD. I think the best part was the cost of the tune. I got it on the Winter sale, and it was really nice to not have to pay someone labor to plug a computer into the OBD-II port.
    2000 Audi A4 1.8T | Santorin Blue | Frankenturbo F21L Mixed Flow | Motoza 550cc Tune | Custom 2.5'' Exhaust w/ Milltek Downpipe | 3'' MAF Housing | 3" Ebay Testpipe | CX Racing FMIC | B6 5 Spoke Wheels | ECS Boost Guage | OEM RS4 Grill
    Orange County, CA
    For the B6 Avant?
    B5 Parts For Sale
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by 10kredline View Post
    I don't have a line on a GTRS, so I would probably get new I would imagine.
    Dumping the money into my sedan would be nice, but I am at the stage in my life where I am getting married, buying a house, blah blah. The sedan is going to take many thousands to get it to the next stage. In the mean time, I'd rather just have a fun daily. And it isn't even just about fun, but more about having a car that functions in certain situations. 150 HP is so slow!
    Quote Originally Posted by Davdraco1 View Post
    Quote Originally Posted by vwblackb5 View Post
    Not going to waste time/money tuning it. It already was and I took it off because the clutch slipped, meaning I will have to upgrade that if I upgrade the turbo.
    Plus, my sedan was also chipped. Not very impressive. I think somewhere around 250awhp, or even a little less, would do my avant right.
    Quote Originally Posted by OverSpun View Post
    For the B6 Avant?
    For my B5 Avant. Just sold the B6 because there was more profit in it for me. Plus, I now have two Ebony Pearl Effect facelift B5's, one Avant, one Sedan. Has perfect is that? Have to keep the B5 Avant around and I think I will for a very long time.
    2000 S4- Working?
    May 17 2014
    Raleigh, NC
    I say go with a the new <Mixedflow F21 that Doug offers. Airflows are comparable to a gt28rs yet but for only $1k...
    Since this vehicle is not your main focus save yourself some time and $$ and just get a FT. Bolt on power, GT28 power, and cheaper.
    Add a GOOD sidemount, dp, and catback along with some 630s and a tune and the car should be as fun as you need it to be without a big turbo.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by rodgertherabit View Post
    I was kinda set on a GTRS but damn that price is attractive. Kinda leaning FT now. Whole kit with fueling for $1800, all I would need is a SMIC and exhaust. Well, that and a clutch, but that doesn't count.
    Eff, might have to start putting this in the works.
    2000 S4- Working?
    May 17 2014
    Raleigh, NC
    get the exhaust on ebay. wont cost much. or the classifieds.
    Doug@FT will set you up with a plug and play kit if you want, hell include hardware + injectors + tune. for a very reasonable price.
    I dont remember if he still has the "FrankenDV" or not, but it was a decent adjustable oversized valve.
    May 17 2014
    Raleigh, NC
    http://cart.frankenturbo.com/Product...oductCode=F21L
    Start there, Season to taste, and hit the button!
    The quality of the turbos are great! I ran a f23 on my GTI for a few years @20+ psi... no issues.
    Spoiler alert, a fully loaded kit including tune + install kit + DV etc is around $2500. But this will get you the MAX performance out of your kit from day 1. Build it right once is my montra
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    I run the GTRS in may car and vs stock its a world of difference it pulls what feels like forever vs a k03 that is out at 5k. I do not DD my car but if I needed to it would be a fine setup only thing a would change Is the 6 puck CM is no fun in traffic. Next, one of my friend and members on here runs the f21 none maxflow and I have been in his car and driven it. we have done pulls all that he went to the dyno with me but had over boosting problems that day due to tuning. no numbers. My GTRS is the faster car as it probable makes 50 more hp but the FT feels more like the stock car would with faster spool but still making power and holding on to boost till 6000 6500k. I don't know a tone about the new maxflow but the word is it should see close to GTRS number?!
    the GTRS is old really but still good and gets the job done, price point if buying all new the F21 its a better deal. Known as the best bang for your buck for sure in the B5 & B6 world.
    I think ( Member nynoah) is selling his FT mani PM him that may save you a buck and will work with FT or GTRS.
    SOLD the GOINHAM A4 ---> GT2860 Project
    Apr 22 2007
    Riverbank, Ca
    I am a huge fan of over turbo and lower boost.
    A GTRS has just as much drivability as the FT. It spools up Stupid fast, has a broad powerband, and is not that much money all said and told. I say GTRS, 15psi and done. 10psi if you want chipped KO3 like power.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Response 3,567,432
    Gt2871R Eliminator on a tubular XSPower Manifold
