Everything was going fine until removing the stock pulley, it was becoming a bear to turn even with plenty of leverage. I had it half way removed and then about 5 minutes ago the center bolt for the CTS removal tool just snapped on me!!!
I was able to remove the tool from the pulley but the pulley is half removed now (meaning the belt wouldn't be aligned properly if I put it back on as it is). The center bolt won't unscrew from the tool either as I can no longer get a sufficient grip on the bolt. Basically, I'm stranded unless someone is local and has a tool to remove my pulley... Not to mention I have no other car and need to travel for work on Monday.
Any tips, help, or ideas would be appreciated. I'd pay handsomely if anyone is local and wants to save the day .
