Results 1 to 22 of 22
    Veteran Member Three Rings Im-AUDI-here's Avatar
    Jun 19 2013
    A bike
    Long Beach, CA
    Mirror cap replacement
    While doing a quick detail on my baby today I found a nice, deep scratch in my passenger side mirror cover. I just ordered a new one from Genuine Audi Parts which should be here next week. Has anyone here had to replace the mirror cover on the SQ and if so, is there a trick to removing the glass without breaking it to bits? I've found some videos online for other models and it doesn't look that difficult but I'm a little concerned about removing the glass itself.
    2016 SQ5 Premium+ - Glacier White Metallic
    2013 A4 Premium - Scuba Blue - (Gone but not forgotten)
    May 20 2010
    Usually the glass on these mirrors just pops out. Turning it all the way to one side and up/down will usually reveal enough of a corner to pull it out. After that, should be held together with screws.
    Jun 19 2013
    A bike
    Long Beach, CA
    That's how it looked on the video. Just wanted to make sure. Thanks!
    Veteran Member Three Rings Adplaya's Avatar
    Apr 25 2015
    TEXAS
    Quote Originally Posted by Im-AUDI-here View Post
    Driver or passenger? Driver mirror has soldered points and can only be removed from the harness not from the mirror itself. Makes it a little trickier, but again no biggie. It does take a decent amount of up force to get the housing off though, so don't be afraid.
    Definitely just point the mirror all the way down and from the top of the mirror push downward and it'll just come right off.
    Mythos Black on Black SQ5
    H&R springs - CF Mirrors - Eurocode Transmission Mount - Black Diamond AWE Touring Exhaust - Hardwired V1 (for the haters) - LaminX
    - 15/20 Spulen Spacers - Thinkware F750 2CH DashCam - 034 Rear Sway Bar and End Links
    Jun 19 2013
    A bike
    Long Beach, CA
    Quote Originally Posted by Adplaya View Post
    Passenger side. Luckily it happened on something easily replaceable but it still hurt a little inside.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    found a MEGA deep (went right through XPEL) scratch on my rear bumper. found out that XPEL only handles 21 psi. trying soooo soooooooo hard to get over it.
    Jun 19 2013
    A bike
    Long Beach, CA
    Quote Originally Posted by drumnjuny View Post
    Yikes! And here I am crying about a mirror cover. That sucks man.
    Oct 04 2014
    Mission Viejo, CA
    Most of the Audi videos on youtube show removing screws once you get the mirror out to remove the cap. There are No screws on the SQ5 mirror caps to remove. The cap is just clipped on. I found it easiest to start at the bottom of the cap on the inside of the housing, then the corner furthest from the car should unclip and then work your way around to the corner closest to the car.
    Although little more coordination you can also replace the housing without disconnecting the mirror. Unclip the mirror and use painters tape to tape it to the car window. Unclip the housing and then pass the mirror through.
    2015 SQ5 OEM+
    Oct 04 2014
    Mission Viejo, CA
    Great opportunity to get some covered in carbon >> http://www.bm1centre.com/us/eurspec-...ror-cover.html
    2015 SQ5 OEM+
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    haha didn't mean to thread jack. i know how you feel though.
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    just a thought but have you ever just thought about wrapping it in vinyl? probably a lot cheaper than a new cover. Also i am ibis and you are glacier and getting it wrapped in gloss black to match the optics package, will make it stand out. If you have silver covers then a new cover is the way to go IMHO
    B6 S4 Cab - Sold
    B7 S4 - Sold, (sadly sold, this was my favorite)
    C6 A6 3.0T - Sold
    B8 S4 - Sold
    2015 SQ5 - Sold
    C7 A6 3.0T - Sold
    2016 SQ5 - Sold
    C7 S6 - Sold
    B9 A5 Sportback - Sold
    C7.5 S6 - Current
    Jun 19 2013
    A bike
    Long Beach, CA
    HA! No worries.
    Quote Originally Posted by Black3.2 View Post
    I do not have the black optics package and I personally like the matte silver mirror caps. I thought about wrapping them but in the end decided that I'd rather just replace it and keep it stock. To be honest with you, replacing it is just my way of being really anal as I'm sure I'd forget about it once I got over the initial shock. It's not even that bad really but as an owner you tend to notice every little thing on your car.
    Veteran Member Three Rings rusq5's Avatar
    Mar 26 2015
    SF Bay Area
    I was walking by my car too close and put a deep, but narrow, 1.5"-2" scratch in the front fender with the clip on the knife in my pocket. It is down to primer or bare metal. I was sick for a good 48 hours.
    OP, don't mean to thread jack. Can you link the vid you saw? I have a set of alum mirror caps I want to put on.
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    Jun 16 2015
    2015 A3 Glacier White Prestige (traded in)
    CA/NM
    Quote Originally Posted by masemoto View Post
    It is a good opportunity to mod the mirror cap..
    I feel the pain to...Just got about gum ball size rock chipped on the passenger side of my windshield...I keep staring at it every time I'm in the car now. =(
    Jun 19 2013
    A bike
    Long Beach, CA
    Quote Originally Posted by _doom View Post
    This is the video that I found. Should be a similar process SQ5.
    https://www.youtube.com/watch?v=AIRHQWYW1WM
    Oct 04 2014
    Mission Viejo, CA
    I assumed the same but the only part that is similar is taking the mirror out. There are no screws to remove and the mirror internals (plugs etc.) are different. Once the mirror is out and disconnected just wrestle the cap off and disconnect the side assist and blinker. Swap the blinker and side assist to the new cap and then reassemble.
    2015 SQ5 OEM+
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    damn. it was most definitely my cousins dog
    Veteran Member Three Rings Thudux's Avatar
    Jun 22 2016
    2012 Jeep Wrangler
    Houston, TX
    I know old thread but instead of opening a new one just seeing if anyone can recap or give me up to date news on how to remove mirror caps on 17' SQ5?
    Nov 02 2018
    Nashville, TN
    It is pretty easy, just like most things on modern cars, you have to remain calm when it feels like your going to brake 1500 little plastic clips every time you do something.
    using at least 3 fingers, (no jokes) pop off the mirror from the outside edge. Remove the wires from the back of the glass. The driver side on mine was a real bish. Take your time and wiggle.
    Then remove two screws from the bottom of the inner shell that go into lower cover. From there, this is where it gets snack, crackle, poppy. I used plastic pry tools and went under the signal light on the mirror, pushing the lower cap down, while pulling the upper cap up and out with my hands. Started from the inside of the mirror (closest to car) and then worked my way out. Pop pop pop pop bingo.
    Not to bad.
    Google ECS AUDI B8 Mirror cap install.
    Not the exact same, but pretty darn close.
    Veteran Member Four Rings MK2SQ's Avatar
    Aug 11 2018
    Quote Originally Posted by sleepyheadn20 View Post
    What exact part did you order from the website for the results? Are the B8 and B9 mirrors the same you think this would work for a B9 SQ5 would like to step up to carbon fiber for resonbile cost
    Prestige B9 SQ5 / Moonlight Blue / S sport / DAP / Dynamic Steering
    JB4 Tuner / ROC-Euro Intake / Lowering Links / 034 Trans Insert / V-FF 109
    / Brembo GT 380mm / AWE Exhaust /
    Build Thread | Instagram @_kademan_v60cc_ | YouTube @MK2 SQ
    Aug 11 2018
    Quote Originally Posted by SQ5/2018 View Post
    Sorry I think I got the wrong person on the quote
    Established Member Two Rings friedliver's Avatar
    Sep 06 2017
    Austin, TX
    Quote Originally Posted by dknick View Post
    Not to bad.
    I don't have side assist, but I only had to remove one screw. It was the one holding the turn signal onto the shell. You don't have to remove the screws on the bottom. The following link has the proper instructions on how to remove the cap.
    https://www.audiworld.com/forums/q5-...14-q5-2884412/
    '14 SQ5
    V-FF 102s 20x10 ·· H&R w/ Bilstein ·· 034 Stage 2 DP w/ TCU tune ·· JHM 207mm Crank Pulley ·· Milltek Exhaust ·· 034 RSB, Brace, Inserts, etc. ·· and various supporting mods...
