Results 1 to 16 of 16
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    What does this line connect to?
    Broke this line when taking the motor out, can't remember what it went to.. Can it be deleted? Or how would I fix it?
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    Looks like part of the ABS system. Don't delete.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    that connects to a plastic line that comes out of like around the intake manifold, its part of the vacuum system. not sure about deleting, i think it leads to a vacuum canister under the drivers fender but i could be wrong.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Oct 27 2014
    Flag/Phx, AZ
    I don't think it goes to the abs system, it dives down somewhere into the driver fender like audacity mentioned. In the vacuum diagram under the hood, there's a line that comes off the n249 and goes to a vacuum reservoir. Could this be that line?
    IG: CJ_s4
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    It connects to the EGR system. Which runs down to your front driver side fender. You are going to need to buy a new hose. Don't ask me how I know.
    Oct 26 2011
    CA
    Check the broken line for the part number. That's how I bought a new one for mine when it got brittle and broke on me.
    Oct 26 2011
    CA
    You need this hose if you broke this end as well. The other end goes under the fender well on the driver side.
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    It attached to a squeeze fitting running beside your ABS system and the other end goes to the manifold I believe, just disconnect that for my engine pull. It's part of the EVAP system
    Oct 26 2011
    CA
    Here is the other part that connects to the EGR tube a posted earlier. I think this assembly part number is 4B0201935N. I could be wrong so, double check it with your Audi dealership. Since this part is different for different makes and models. Start removing your fender splash shields to remove the old broken hose to swap the new one in. It's not that hard of a job.
    Aug 05 2011
    Memphis, TN for now!
    Part of vacuum system that goes to vacuum reservoir in the fender. It also eventually goes to a pump that is part of EVAP/Fuel tank stuff. You will get a code obviously with this broken. If you cap off things on the engine side it will run/work OK but you won't have vacuum from the reservoir under certain throttle conditions(boost to vacuum) to help move those diverter valves.
    You could easily connect the broken end back on with a hose over the two broke pieces and some clamps. Do you have the broken end?
    Sep 09 2014
    Grand Rapids, Michigan
    This leads to the vacuum reservoir that is part of the n249 system. you definitely want that hooked up/repaired. It helps the Diverter valves operate independently of the intake manifold under high boost (WOT) and partial throttle applications.
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Finally some correct information!
    Quote Originally Posted by xalents23 View Post
    These cars don't have EGR. That is a line for the vacuum reservoir. And the vacuum is used to open the by-pass valves and the auxiliary air valves if those are in the car.
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    i think on tip cars it is also connected to the SAI system. i remember having to remove some extra lines when deleting the SAI.
    Oct 26 2011
    CA
    Quote Originally Posted by okkim View Post
    Yes, they do they are also called combi valves. Which are used on tiptronic Audi's. My car was a tip converted to a 6-speed.
    The EGR valve, or combi valve, is a part of the secondary air injection system that helps keep exhaust emission levels low. This valve is operated by vacuum to open and close an internal diaphragm, allowing air to be directed or stopped to the exhaust or intake system at idle or cruising speeds. If faulty, you may experience symptoms similar to a vacuum leak, and also receive an incorrect air flow trouble code.
    Dec 07 2004
    Finland
    EGR = Exhaust Gas Recirculation. I know very well how the air flows in our cars, and it doesn't include exhaust gas recirculation. The air is pumped to the exhaust ports via channel behind the cylinder head, and from there goes to the exhaust. The exhaust gas never gets recirculated.
    Combi valves are just air valves.
    Aug 05 2011
    Here are the diagrams for the line you broke... your broken part is between 12 and 11 in the engine bay between the manifold and vacuum reservoir:
