Originally Posted by
Brillo
I don't think toying with the clutch plate will make any difference. I occasionally have this problem (95,000miles). I use the Pentosin MT fluid which I'm told is the factory fill. My solution is to shift into second then first. This works 95% of the time. If it doesn't I just depress the clutch again and second then first - that never fails.
This, instead of clutching again I just go into third then first
If your on super flat ground and you do it you'll notice the car moves a tiny bit
Although others may have destroyed their transmissions by always forcing it into first this is not a design flaw
This is a flaw of having awd, the transmission has to move all four wheels when it's slightly out of alignment, every manual I have owned has moved the car when shifting into a gear but because they were always two wheel drive it could move them, now that it's four wheels I gotta just go into another gear first which my fiesta I had to do with as well
The difference is that each higher gear has to move the wheels less thus making it easier thus aligning the transmission for you to then go into first
If I'm on a slight incline I'll roll the car a tiny bit and it always goes into first
Use the methods as stated here and you won't damage it as long as you regularly change the fluid and don't drive like
dg2b
Still the original oil. But I will change the oil in the next two weeks. Hopefully this makes a difference.
Which you haven't, do it now!
Maybe you can save he tranny in time but just keep in mind that since this is the first change at such a high mileage that damage may already be caused to other things like the shift collars forks and synchros
I used the VW oil because it's the only one that everyone says they have either no or minimal shifting issues when cold, being able to shift every winter was higher than the price on my priority list so I went with VW
You need 3 liters and it'll be 90$ if you go that route (I have no sales tax so more for you suckers
Change fluid and report back
Edit: disclaimer just in case I came off a little harsh
Opinions are like assholes, everyone's got one, and I've sure as hell got one
Sent from my iPhone using
Audizine
