Results 1 to 11 of 11
Thread: 01e Question
    Aug 24 2014
    Newport Beach, CA
    01e Question
    I'm picking up a rebuilt 01e this weekend but wanted to confirm since I want to make 100% sure after reading through various threads I had the correct assumption. The transmission I'm buying is from a 2000 S4, my car is 2001 so theoretically both both have the early style linkage. Is there anything else that is different between the early and late versions are the S4 trans besides the shift linkage?
    2024 M3 Comp xDrive
    Veteran Member Four Rings Tjtalan's Avatar
    Jul 19 2014
    Tulsa
    Everything is the same.
    Aug 24 2014
    Newport Beach, CA
    Thanks Tom, that's what I was looking for.
    2024 M3 Comp xDrive
    Veteran Member Three Rings Blake2423's Avatar
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    Just swap all your linkage from your car onto the new trans and youll be fine.
    01.5 S4 AVANT Brilliant Black - SRM SMIC, SRM K24 HYBRID, SRM 102MM INTAKE, 1000cc INJECTORS, GET WATKINS E85 TUNE, JHM STAGE 4 CLUTCH, JHM SYNCHROS, SRM 3INCH DOWNPIPES, AWE MID MUFFLER EXHAUST, JHM SHIFTER, BREMBO GT KIT FRONT AND REAR, H&R RSS CLUBSPORT COILOVERS, 034 swaybar and links, AWE DRIVETRAIN STABILIZER, STERN ENGINE/TRANS MOUNTS AND REAR DIFF BUSHINGS, ECS REAR DIFF MOUNT
    Aug 24 2014
    Newport Beach, CA
    Thanks Blake, I'm going to upgrade to the JHM solid linkage and and HD linkage at the same time. Already have the JHM short shifter.
    2024 M3 Comp xDrive
    Jul 19 2014
    Tulsa
    Quote Originally Posted by christianb5s4 View Post
    What's up with your trans, I thought you had a JHM kit?
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    That'll do nicely, makes everything very precise!
    Jul 07 2009
    Alberta, Canada
    Make sure you use the correct shift shaft cover and/or bolt your linkage to the correct spot!
    Aug 24 2014
    Newport Beach, CA
    The car has the minimum 1st to 2nd gear and rebuild, so that's good. But the 3rd gear synchro is weak, it grinds if I don't granny shift going from 2nd to 3rd over 5500 rpm unfortunately. Done that since I bought it.
    JVD, do you have a picture of the shaft cover?
    2024 M3 Comp xDrive
    Jul 07 2009
    Alberta, Canada
    Aug 24 2014
    Newport Beach, CA
    I see what you mean now, that's a great picture.
    2024 M3 Comp xDrive
